There is a small fusible link on the rear of the cigarette lighter recepticle. It is common for this link to fail when overloaded. That's it's purpose. That recepicle should not be used for anything other than light duty; cell phone chargers and the like.
-B-
my cigarette lighter doesn't heat the actual lighter or power anything i plug into it.... i've replaced the fuse and the light in there does come on when i turn the lights on.... any ideas??
Not that I suggest this for a permanent fix, but in a bind, you can remove the little composite washer that separates the two fused pieces and it will work just fine. It is still fused at the box, so it shouldn't be dangerous, but the fusible link is there for a reason........I just haven't figured it out......
Dan
