Chunky Prestone
MA
I replaced some radiator hoses the other day and so flushed the cooling system and refilled it. What I refilled it with was a mix of green coolants that I have had stored in the garage for who knows how long. Prestone, Texaco something, and another brand I can't remember. They were all unused but had all been opened and sitting there for some time (years). As I was pouring them in I noticed some rippling of the stream and when I looked in the bottle of coolant I saw that there was some kind of congealed stuff floating around in there. Well, I didn't find anything on the internet about it and so figured I should have just shaken the bottles up first. Truck ran great until it didn't. Later that day 2 of my cylinders stopped firing. I didn't think much about the cooling system but now as I'm about to do a compression test it occurred to me that I might ask on here what the heck was in the coolant and if it might have compromised my Beasty. Yo, what up?
Thanks!
I have never personally seen antifreeze congeal. I am wondering if you have a mixture of normal ethylene glycol and possibly the organic stuff that supposedly lasts longer. Here is an article showing the congealed mess that people have found as a result of intermixing types:
Do Not Mix OAT's and EG's Antifreeze
Short answer: You can't go by color, as the auto manufacturers specify the colors, and they can be different for the same type of coolant, or the same color for different types. Your Cruiser should be filled with traditional old-school (usually green) IAT coolant and not mixed with either OAT or HOAT, as it can cause sludging according to some manufacturers (amongst other long-term issues). I don't know how quickly a coolant mixture possibly sludges and if it would be your root cause, so I don't know if it's worth your time to flush the block on an engine that's not running. If it were me, I'd flush it, but I'm paranoid.
Longer answer (I did a bunch of reading about this awhile back, as I was pissed about paying big $$$ for Mopar coolant for the wife's Jeep):
The older IAT stuff (traditionally green, EG) is what we should be using as it has silicates and phosphates (corrosion inhibitors) for our brass radiators and cast iron components.
OAT is the early long-life PG stuff like Dexcool that GM used (still uses?) that was originally orange, but now comes in a bunch of colors. It usually doesn't have any silicates or phosphates, but is better for the environment.
HOAT is the newer stuff that many manufacturers use that I know comes in at least yellow and pink (it's what goes in the wife's Jeep and my Tacoma). It's the compromise between OAT/IAT, and has small amount of phosphates or silicates in it (I can't remember which).
From what I understand, you're not really supposed to mix any of them as you're altering the composition of corrosion inhibitors (or lack thereof), altering the service interval, and could be promoting electrolysis between brass, cast iron, and aluminum components. To my knowledge, the sludging happens when you mix IAT types with either OAT or HOAT, or OAT with some types of HOAT. There are some universal coolants that claim compatibility with all three types, but I'm personally weary of that. I just stick with generic green IAT in the Cruiser, the Mopar yellow HOAT in the Jeep, and the Toyota pink HOAT in the Tacoma.
It was all the old-school ethylene glycol stuff. It was congealed in the bottles and settled on the bottom. Some went into my truck. The truck ran fine for 20 or 30 miles. Did not overheat or burst so I don't think anything got blocked up...so far.
I doubt the coolant affected your engine condition/life/integrity. And I have used old, opened coolant without issue in the past. But, Tezmac is right in that you don't want to mix 'dexcool' or OAT stuff with regular green. Antifreeze is a lot more difficult than it used to be, so it's very easy to get confused.
At some point, if you put lumpy coolant in your engine, would drain, flush, and replace.
