I still remember the first time I took my FJ40 out of the ~20 mile radius around home....
Took the ferry to Seattle, drove 50 North... Parked and spent most of the day at some event...
Got back in the FJ40, started driving back and it died. After a bit of troubleshooting and some failed calls for help... Discovered it was out of gas, never mind the gas gauge showing 1/2 tank. (found over time that it went from full to 1/2 and stayed there no matter how empty the tank was.)
Wife finally shows up with gas can (and chain and come along, still wasn't sure what was wrong 2 hours earlier when she left). Fill it up with gas and start to follow her home. By now, it's late, ferries run too far apart, decided to take the drive down I5 from Everett to Tacoma in the rain and darkness.
Intermittent windshield wipers, not by design, just a bad ground.
Water seeping in between the windshield and the roof, PO didn't bolt that down, didn't seal, just kept spraying me.
Heater worked, high only, wiring on the resistor for low speed wasn't working (burned off?).
Headlights? there was enough traffic and streetlights my mid '70s sealed beam lighting technology wasn't much of an issue, it will be in less populated areas.
Very noisy.
Steering was OK. It's developed a bit of a wobble recently I need to look at, but back then, reasonably stable at 55. And I have front disks, my FJ40 stops well (after resolving some vacuum issues that made the booster more of a liability...).
And, stopping for gas every hour. Now understanding the 1/2 tank on the gauge means it's less then 1/2 full, but no real idea of how much less (even using the whole tank, it's still small).
Uhaul has trailers for $55 a day, if you decide that maybe this isn't exactly the kinda adventure you want on day one (I already had my FJ40 for at least a month by then, used a Uhaul trailer to get it home). You'll probably save on gas....
