never discount the new distributor. I’ve had brand new out of the box units fail. The parts stores are flooded with inferior products.i’ve only run this engine for 4 months and the distributor was brand new.
Lots of good advice in this thread.
missed your post originally. i have a edelbrock performer carb. this isn’t seeing steep hills or angles where i play for now so its what i had when this engine came out of my chevelleWhat carb are you using.?
Maybe it doesn’t like all that fresh Saskatchewan air. Haha just teasing.
Those carbs work pretty good right out of the box. And even rebuilt and just cleaned up. I just sent the one off of my gen 1 one out to my dad in Sask to put on one of his grain trucks taking the Holley off of it. I did have minor heat soak on mine but not bad I put the Holley heat Shield setup under my Edelbrock it is an aluminum plate shield then a gasket then a aluminum plate then gasket then plate then gasket it works but who knows I also put the spring loaded needle and seat into my eldelbrodk but after years of stalling in off camber I shelved it and went to the Rochester. But loved the edelbrock it would work good ripping around SASK. did you go hard line from fuel pump to carb. I had to toss the rubber hose and go hard line up to carb also. New pump may do the trick. Cheers.missed your post originally. i have a edelbrock performer carb. this isn’t seeing steep hills or angles where i play for now so its what i had when this engine came out of my chevelle
it’s been rebuilt to stock specs. i could probably play with needles and jets a little but it was running fine and isnt now. those would be more fine tuning items. i want to fix this issue first. i’ll be home tomorrow and see if i can get a new pump monday
dingBlow compressed air back into the tank from the pump side to see id the hard lines in the tank are partially clogged. Mine did that and starved it for fuel but idled fine.
