SOLD Chesnee, SC FJ62 on FZJ80 roller, LS3 Connect & Cruise package, New split case PROJECT TRUCK
Status
Not open for further replies.
Chesnee, SC
Year
1988
  1. 60 Series
CHESNEE, South Carolina 29323 United States
Mileage
1
Break out your calculator and start adding everything up.
$35K
Don't bother low balling, it will not be received in good humor
-I have something different. A FJ62 body mounted on an FZJ 80 chassis. In this configuration the
suspension is at stock height.
- Dobinson progressive springs along with OEM new shocks to go with it.
-The frame is shortened, rear section raised to accommodate 62 body.
-Frame has been media blasted, epoxy primed and painted gloss black as have axle housings
and suspension components.
-Axles are rebuilt
-Under body, inner body floor, outer and inner firewall and inner roof have been stripped to bare metal, epoxy
primed, sprayed with Lizard Skin sound and temp control and painted black
-Floor has been covered in Dynamatt
-Front clip is off
-I have all parts for the truck
-New Trail Tailor rear bumper with swing out
-Heater core is new and installed
-AC Evap replaced with new
-All new calipers and rotors
-New upper lower dash
-New under hood blanket
-New stainless battery trays
tex-1-webp.3878777
tex-2-webp.3878778
tex-3-webp.3878779
tex-4-webp.3878780
tex-5-webp.3878781
Round 2
Drive train, Has been installed in another 160, ran 5 miles and removed. Ready to drop in this truck.
LS3/4L70E Connect & Cruise package, AA adapter to brand new Split case.
-Holley front drive assembly installed
-Twin stick set installed
-Drive shafts cut and balanced
-Hooker headers
-Ron Davis radiator and fans
-Full harness and computers
-Gas pedal
Hi Stan! Some of your pictures not show up on the second and third post mostly for me!
Try refresh
They are all showing up for me
They originate on my computer so maybe that is part of it
Thanks Brett, I went through and re posted the pics.
I hope someone agrees with you. It's a 142 Kit. I have the frame side motor mounts as well.
All the heavy lifting is done.
I had an FJ142 built by TLC 4x4/ICON. I was the 3rd owner from when it was modified/restored, but it came with the build invoices. The total bill came out to $211k including the 2 donor trucks in 2011… So about $2 mil in 2025 shekels. Overall the build was somewhat crude- especially for the price, but I sure didn’t pay anywhere close to that.
This is one heck of a deal if you have the means
I have one of these (LS3/430 + 6L80E Connect and Cruise) locked axles. It’s for my wife. $211k is too much, but that’s Jonathan Ward!
$35k is a very good price for that stage with the parts shown.
Truck is looking good. I have always liked a white 60/62.
How much lift do you have? Mine is stock height springs, looks like a 62 with a 2-3" lift with 34" tires.
Not to hijack the thread, I'm doing pretty much the same thing. Anyone can guide me to a build thread? Trying to figure out the mounting points for the engine. Why re-engineer if someone has already done it...
Status
