checking/topping off transmission & transfer case fluids?
SoCal - westsiiiide
so, I have some small leaks on my floor from the transfer case (through the seal at the parking brake) and at a seal in the transmission.
how often should I check the fluid levels AND
what is the best fill level for each? until the top of the fill plug when I unscrew it?
Checking depends on how fast the leak is. The very small leaks I used to have meant I checked fluid level before major trips. Every couple of months.
Yep. Fill till it comes out the fill plug hole. I always overfilled just a tad.
thanks. I would not consider them small leaks, but not huge either. they drip daily for sure though. especially when warm and just run.
I am getting ready to do the seal at the parking brake (and the parking brakes) as that is the bigest leak and easiest to fix myself I believe. that way, I can fix a leak and get my parking brake back.
talk to gary kardum (mudrak custom cruisers)...he can machine out your speedo housing to accept two seals...won't leak again! one of the best things i ever did.
If the brake drum for the parking brake is scored where the seal contacts it, you can put a speedi sleeve on and take care of the problem along with a new seal. :)
