Checked front bearings/square plug observations
Both trucks had developed some front wheel slack and the 93 was developing a slight braking shimmy from freeway speeds so I opened them up today. Found some interesting observations. Both bearing sets were packed with Mobil 1 red grease during front axle repacks which I used purple Amsoil in. The 93's repack has 25,000 miles on it, the 97's has 55,000 miles on it and will get repacked later in the summer.
1993 - All I planned to do was check the bearing preload but couldn't resist a peek at the outer bearings. The Mobil 1 synthetic grease was all still red in the bearings, and I just smeared a bit of fresh grease on it and adjusted the preload. Impressive that the grease is holding up so well at 25,000 miles.
1997 - found the bearings in great shape still with red Mobil 1 in the bearing retainer gaps and the rest of the grease looking very light in color - not much suspended metal wear particles. At about the 40,000 mile mark from the repack, I put much more grease in the square plug than the usual few squirts and I used black grease. I did this to ensure the knuckle was full as I planned to run it out to 60,000 miles or more before repacking. Here's the interesting part. I've proven before that grease from the square plug gets into the birfield by using different color greases, but the black grease here also made it through the spindle bushing, with minor accumulation on the back of the drive plates. Impressive. So, if you're reading this and your spindle bushing is making noise you MAY* successfully get grease into it by filling the knuckle well if you're away from home or can't do the repack soon. I will check but I think I put over a half tube in each knuckle of this black grease.
Interestingly, the left bearing felt the loosest, but I only turned the adjuster nut 1/8th turn tighter on it. The right bearing felt so tight (tire shake) I nearly did not open it, but when I did I was shocked to find I turned the big 54mm nut a full turn and a quarter tighter with my fingers. Little lesson in that, eh?
* MAY because if your spindle has been driven dry and the dried overheated grease blocked those clever grease channels in the bronze spindle bushing then it may not get through as well as mine did. I guess you could pull the drive plates a couple weeks after greasing to confirm.
DougM
Interesting. I just did the front axle this past weekend, along with rotors/calipers/etc. Last time was my first time, on my old 93, I followed the FSM verbatim, in adjusting the preload. I think it was marginally loose. But I didn't have it long after I did the service and didn't recheck it.
This time on my 96, (first time on the 96, second time on an 80 series) I found that it had Timken wheel bearings (proof it had axle service by a PO) and one of the DS races was pitted. This time I adjusted bearing preload based on the fish scale. After following the FSM sequence, I just tightened the nut until I was at about 10-11lbs preload, which ended up being near 43 ft-lbs. After test driving, I found that some subtle rattle/knocks were gone, and the steering was tighter than before. Even though I changed out all my brake components, looking back, I think part of my brake shudder was from loose wheel bearings, as the pulsing was intermittent, probably had to do with some side load on the bearing on braking, or something like that.
I went thru my rite of passage this weekend(well, the last two weekends) on my 97 lx (approx 140k). I was pushing grease out the drivers side(occasional drip in the driveway, but would sling it onto the tie rod/ steering arms at speed), but kept adding grease as a stopgap. I figured as long as i had grease coming out, it meant i still had grease in it.... I had what felt like a warped rotor on the left front, and an ever increasing harmonic vibration at about 50mph under power. Wheel bearing test did not show looseness. I would get an occasional click on a full lock left hand turn first thing in the morning (maybe 1x every few weeks). I've had the LX for about 70k miles, so i got the full meal deal kit from dan, and bearings from kurt(dan was out of stock on the bearings). Had the parts since March, but too much out of town work projects for me to tear into it until now. I'm sure my vibration in the left front was caused by a warped rotor and worn bearings. I'm sure they both accelerated the heat/wear in the other.
Some observations I made during my teardown and reassembly:
my passenger side had been open before. New timken bearings, clean grease in hub, and I believe a new(er) birf. It was tighter in articulation than my drivers side birf, and had less wear. Wheel bearings were free rolling when cleaned. No obvious damage from heat or wear. No pitting or scoring on the spindle, and trunion bearings could have been reused. Bushing looked clean, and i did have grease at the drive flange, so it was flowing along the length of the axle shaft.
my driver side (which was pushing grease out the felt seal/birf soup) had gotten a little too hot. The wheel bearing races were slightly browned from the heat, and the outer race(closest to the drive flange) was easy to tap out. Bearing grease was pretty cooked as well. Bearings were on their way out, but would not at a point of failure. I was wise not to wait any longer. Fortunately, there was no pitting, scoring, or damage to the spindle. Trunion bearings could have been reused. Birf moved very easily(looser than the passenger side), and had a couple of different wear areas, but were typical with other folks' pics. Inner axle shaft seal was toast, causing the birf soup.
Reassembly: I packed the birfs to a point where i could still see the axle shaft going in and not fouling the C Clip (did that the first one, and spent an hour with a file cleaning things up.....moron.) I then used a needle attachment and liberally shot grease inside the birf at all angles to get it fully packed. I used about 1 1/2 tubs of moly grease in each knuckle when sliding the axles in. I left some space for expansion and settling, and will check the levels this weekend.
When placing the spindles on, i took Doug's advice, and liberally greased the bushing, smeared it on the axle shaft, and inside the spindle as i slid it on. I then used the needle attachment and pumped between the axle and spindle until grease started oozin back at me. I also put 4 of the bolts in and snugged the spindle into place prior to the brake dust shield, flanges, etc. Made it much easier to place those bits on and not have to worry about stuff floppin around or not lining up.
I used mobil 1 grease in the wheel bearings and trunion bearings, packed as much in as i could and put em in the fridge. I used about 1 1/2 tubs total between the two sides(had alot of excess that i cleaned up). I had quite a bit ooze out when tightening the thrust washer the first time.
Again, thanks to Doug, I noticed my drivers side was not fully seating onto the spindle. Took a couple of good attempts to get it seated. Passenger side went on without as much pain.
I set my preload on both sides at 10lbs on my fish scale, and then rechecked my drivers side (i did that side first) to verify the additional resistance of the passenger side assembly didnt impact it. I figure as the bearings and grease go through some heat cycles, they will loosen up a bit. My concern was that if folks set their preload at the low end at the start, it could cause it to be too loose after a while.
My vibration is gone, braking is solid, and the steering feels tighter. I need to drop my driveshafts and clean/regrease them. That should take away the last bit of vibration that I have. Now that I know the how-to, i wont be concerned about digging into the front end. Next up will be the rear wheel bearings, rear rotors and parkin brake stuff....
Thanks again to Doug and everyone on here. I took this on with nothing more than the FSM, the FAQ, and tons of posts here. I had a couple of boneheaded moments, but thats all part of the "fun"....
Doug, you have mixed a different moly grease with the Amsoil moly grease from the last birf job through the square hole? This is just probably my ignorance, but I thought that Amsoil didn't mix well with other moly grease or maybe it some tidbit I read from their site.
I ask this question as I get pretty darn tired trying source Amsoil.
......, but I thought that Amsoil didn't mix well with other moly grease or maybe it some tidbit I read from their site.
Amsoil synthetic grease, gear oil and motor oil will mix well with most other synthetic and all dino products for the same type and application. The downside is: the resulting mixture takes on the properties of the lowest quality product. For example, if you're running Amsoil 100% synthetic motor oil and you need to add a quart, but no Amsoil is available. You can add a quart of Pennsoil dino oil to get you home, but now your long interval synthetic oil is compromised and you need to change oil at the Pennsoil dino schedule. Not a big deal, but good to know for longevity's sake.
If you go to this site, it will help you find a local active Amsoil rep. Just click on the yellow "Find an Amsoil dealer near you" link and plug in your zip code:
https://www.amsoil.com/a/Synthetic-Grease
I'm an inactive dealer, myself, and order my needs through another active dealer.
After rebuilding my front end, I have torn each side apart about 6 times in 6 months trying to solve my woo woo blues. I can get to the axle in about 30 minutes after pulling into the garage. I used amsoil for the knuckle, and mobil 1 for the wheel bearings. Every time I have busted the front end apart, the amsoil has always migrated from the knuckle past the c-clip, and into/onto the drive flange. There is absolutely no doubt whatsoever that if you forget to lube the brass bushing and spindle area, the grease will get there as long as you pump it into the square fill hole.
I think I've given up on the Woo Woo blues though, its my front diff about to hatch in another 300k, if I nurse it:p, maybe 50k if I beat it like a rented donkey:grinpimp:
What is woowoo blue?
The woo woo blues is a sound, sounds like a loose wheel bearing, but isn't. I get it from about 45 MPH to 60 MPH, sometimes it comes on and i hear it at 45 MPH, sometimes I hear it at 55 MPH, sometimes never. I figure its the front pumpkin, gears, pinion, carrier bearings, something in there, woo wooing away.
After talking with a few friends of mine, this is the same sound they heard in their rides(jeeps, GMC's), before they hatched their front diff's. Theres only one difference, mine is a Toyota, I bet I can get it to woo woo for 5 years, not 5 days, before it hatches. And when it does, I will probably be able to hit the CDL and keep driving for another 5 years:cheers:. So WOO WOO
Tenzig,
Give some consideration that your sound may be tire related. I did this work because I was aware some slack was developing, but what gave it urgency was that one day I noticed a bearing sound as I drove along a quiet road at slow speed. Hopped in my wife's truck and heard it also but quieter. Swapped the winter tires/rims onto my truck - dead silent. They both have Bridgestone Revo tires and what's happening is they're getting noisy as they wear. Just one day I realized I'd been hearing that sound for a while. So consider that your tires may be the culprit. I was about to post the Revo comment to see if others are noting it since many here are using them.
DougM
