Check Engine Light
Western Washington
My '92 FJ80 has been running strong for 180k miles. Last week the check engine light came on, and I can't figure out the issue. All the big stuff checks out and the motor is running as good as ever. The only issue I can find is a pretty bad exhaust leak. I don't really want to take it in, and wanted to know if any has run into a phantom light before. Thanks.
did you go to autozone and have them read the code? if not this is a great place to start! there are lots of different reasons why the CEL comes on!
While not exactly the same vehicles. My 2003 Toyota Truck check engine light when on last week. I replaced the gas cap with a new one and nothing happened.
I then filled up with premium fuel and instantly the light came off when I started the truck after the fill up.
I hope this helps.
Whoa, Autozone may not have the capability to just scan an OBD1 vehicle, so as easy as it sounds you may not be able to just "Get in the Zone" and have them find your problem, it may not be possible. As far as the idea of replacing your gas cap then filling up with premium. Well when you replaced your gas cap the light wont just reset, it has to have a certain number of drive cycles, sounds like a coincidence that you happened to turn off the car to fill it up then when you turned it back on it was done with its drive cycle, BTW your 2003 is OBD2 so you coulda "got in the zone!"
An educated guess on the FJ's CEL would be the exhaust leak caused the O2 to go bad, or it is just causing its readings to be WAY off and causing the CEL to come on. The good thing about OBD1 is once youve fixed the problem you can just disconnect the battery cable reconnect it after letting it sit for a minute and viola no more CEL!
As previously posted, your 92 is pre-OBD-II so it cannot be scanned with an OBD-II scanner like the 96 and up trucks. You can still pull your code by jumping 2 pins in the diagnostic port and counting the MIL flashes. This has been detailed many times so search for the proper procedure and post back with the code and we will try to help.
Partially correct. Many OBD-II codes are tied to the drive cycle. Some require 2 drive cycles. Some codes are not linked to the drive cycle at all and will in fact, self correct if the conditions that caused the MIL are no longer present. One of those is the pressure in the tank and it is possible for a new fuel cap to "correct" the problem. I am not aware of any OBD-II code that can be corrected with premium fuel but is possible that the stop to refuel cleared the MIL. The fact that he used premium might have been coincidence as you stated. It is also possible that some fuel additives in premium might have helped with an O2 sensor code or an engine misfire code. Who knows for sure. Stranger things have happened.
-B-
-B-
Zees is trru!
I could imagine a high performance car owner putting in crap gas and getting more KR than his car could adjust for and having a misfire or knock code coming up, then he could filler up with premium and the light would go away.
