- Joined
- Feb 13, 2008
- Threads
- 5
- Messages
- 9
- Location
- I LIVE IN BARCELONA, VENEZUELA
- Website
- www.aventuragps.com.ve
my check engine indicator turns on randomly from time to time with no other symptom, what could it be?
Who knows, it could be an O2 sensor, loose vacuum hose or a number of other things. My light stays on all the time but the truck runs great so I dont really care, still getting 16-17mpg so it cant be too bad.
I got the same problem as you yesterday. The Check Engine light was on for no reason, all others are fine. I drove to the nearest Autozone store (find their store near you at autozone.com), they read the code and fix it for free. A young technician used a hand set to link to the plug in the fuse box under the left side of the wheel, then, re-programmed it. The light went off, and never comes back again.
Pepboys asked for $89.99 for this! While in autozone store is totally free.
If it's an EGR code or even a misfire, I don't think they would fix it for free... They'll pull the code and erase it for free., but the code could very well come back.
97 Lx450 Misfires And Shakes
Posted 06-17-08 at 03:04 PM by LX450INOC
Help! I have a 1997 LX450 W/ 105K Miles, replaced head gasket with full head rebuild, replaced ECM and it still shakes and misfires really bad but happens intermittentley - any suggestions on what else might be going on ? My CEL is also flashing
... shakes and misfires really bad but happens intermittentley - any suggestions on what else might be going on ?
OBD-II vehicles need a special "reader" (aka scanner) to pull the code. AutoZone stores will usually do this for no charge. Most scanners will also allow you to reset the code though that doesn't "fix" anything.
