Cheap cowl vent drain fix
Southern Oregon
I found a cheap replacement for the 65-74 FJ40 cowl vent drain tubes. Both of mine were missing so I looked at SOR had available. My cruiser needs money poured into more critical places first, but I was getting tired of my fuse block being constantly dripped on. I found that a 27 x 1 3/8 (700x35-38c) bicycle tube fits great. Be sure to get one that is heavy duty or thorn resistant, as they have much heavier walls and won't kink so easily. The shop I work at sells them for $5.98, and one was plenty to do both drains.
Hope this helps someone out.
Aaland
Heh, I used heater hose... not the easiest stuff to work with but it got the job done.
I got a piece of thin flat plastic from Tap plastics and sealed up the vent completely. Put it below the vent grill. I dont live in the deasert, so dont see much use in the vent at all- except for letting water pour on the electrical.
-Dustin
cowl vent on a 1976
Does this even work on a 1976. I read some where that they sealed these up at the factory at some point. Then completely removed them in later years ? I have some rust in that area whats the best way to clean it up and seal it ?
A 76 does have the grill but the (fresh air) vent does not function. All it does is collect water which is why the vent tubes are important. If the tubes get plugged then the water has a place to sit and cause rust. I like the idea someone mentioned about sealing the tub right under the grill. This could keep the factory "look" but prevent the problems of the tubes getting plugged and then causing water to collect.
