I was hoping that I would have had more time to document and keep this up to date as the build went on, however, it was insane crunch time and did barely had time to sleep while preparing all the new stuff for expo. I'm still putting finishing touches on the rig, so i'll try and catch up best I can in this post.
The truck now has 37s fitted, a complete custom rear storage system that was a big collaboration effort with Aiden James Customs in Santa Ana, and we debuted it all at Overland Expo West a couple weeks ago. We sound deadened the entire floor and reare wheel wells prior to having the system installed. We also installed a layer of closed cell foam over top of the butyl you see here. Highly recommend doing that as it will add thermal insulation as well as higher frequency damping.
And here's the drawer system installed! It's quite unique and designed to keep heavy items like the 3x Battle Born Batteries low, water tank low, fridge low, and spare parts storage low all while having a built-in fold-down induction cook top that encloses the fridge (and slides out with the fridge). This specific system deletes the 2nd row seat and allows for 40" drawers, and also makes a nice spot for an electrical panel for the 3000w inverter, solar controller, DC to DC converter, 120v panel/outlets, weboost, and Victron display for the whole system. This has turned into a pretty much dream build and I cannot be happier with the outcome!
I'm now currently in the process of installing the 10gal water tank, pump, and everything else to support it.
The pump/accumulator are being mounted on the front panel of the 2nd row seat delete, and the tank will mount right behind that with lines going to a spigot out back, as well as another sprayer/bottle filler at the side of the rig. These two photos are where the pump/accumulator are mounting and the 2nd shows approximate final placement of the tank. There's going to be a plexiglass sealedbarrier between the tank/lines and batteries should anything bad happen/leak. There will also be a water level sensor installed and hooked up to the victron system. The whole system can accept up to 4 external temp sensors as well as 4 liquid level sensors. Pretty nuts!
Final image of how the rig sits as of right now. I'm REALLY proud of how it all came out and can't wait to get the rest dialed in. The 37s haven't been 100% fitted up front for full stuff, but most medium trails it is fine and rides great! The front suspension is an all-new kit from Alpha Foxtrot Design. It's a +2 width (trail friendly!) and +1.5 forward kit with upper/lower arms and complete beef custom knuckle. We are still dialing it in but keep an eye out as it's a really great kit so far and I really like the track width.
Additional changes were McQueen Fiberglass fenders up front to fit the new 37" Toyos, Alpine MultiCam wrap from Image Craft and triple LP9s up front that I've been dying to get on the front for years!
View attachment 3029220View attachment 3029232View attachment 3029233
