Charcoal Canister Question
Gainesville
I have a faint fuel smell in the cabin of my LC. I have changed the gas cap and also made sure there is not a crack in the fuel tank.
I pulled out the charcoal canister per the FSM and evaluated it.
How much resistance to flow is there suppose to be when you inject air in this? The FSM says 1 psi so I tried to blow through the tank pipe and could not get any air through it without resistance. Using compressed air and holding the purge pipe closed, there was flow through the drain pipe, but it seemed to take a lot of force. Is this normal or does this thing need replaced?
Thanks.
Subscribed,
Need to confirm mine as well.
I get the hiss when releasing gas cap.
I'd like to rip the whole EGR out on this.
Its a joke when the truck gets 13 mpg.
You should be able to blow through it. There's a little resistance but not much. Your check valves are probably gummed up. I'd get a new one.
I ripped mine apart and found that the valves/ports weren't resistant to flow. It seemed to be the filter fabric and possibly the small filter port in the center at top. I did replace the charcoal after sieving to remove the super-fine particles which I assumed would only further clog the filter fabric.. Did carbclean the valves and ports and make sure rhey flowed well.. Then used carb cleaner on the fabric. Put it back together and the fuel tank rush is as bad as ever.
Also make sure your tank-to-canister line flows free. Have seen a couple people on here say theirs was clogged.
I'm moving on to check the vsv and rest of the system.
The check valve is nothing but a ball.....try some penetrating oil of choice into the upper ports after a few shots of brake or carb cleaner. Blow air rhrough all 3 ports while blocking one other in rotating fashion. I bet you see a big difference. Scrapping this OEM part for the plastic autozone one right away seems like a waste to me. If it doesn't help, then proceed with the plastic part but at least give it a shot. Jmo
Subscribed because I also get gas cap hiss sometimes...
You can't buy the OEM vapor canister from Toyota any longer. I took mine apart and replaced the charcoal , cleaned the check valve thoroughly with carb cleaner and compressed air, put it all back together and resealed the top with JB Weld. No hissing gas cap since. If you don't want to rebuild the OEM canister you can purchase a VC-120 Duralast canister at Auto Zone.
How did you replace the charcoal? Thanks
Subscribed,
I removed my cc along with my EGR. I now, have no gas cap hiss. I simply vented the gas tank to the stock location where the hose on the bottom of the oem cc vented to. Read through the thread in my sig
^X2 what 120mm said. There's a couple of threads on here with pics showing how to rebuild to OEM canister.
Just a heads up, I ordered the exact charcoal linked in those threads. there were a TON of very fine particles that I suspect over time would settle down and potentially clog up the lower fabric filter.
The charcoal toyota put in mine was all very uniform in size.
True to my OCD tendencies, I used some mesh to sieve (filter, kinda) out the very fine particles and put it all back together.
But as mentioned.. I still get tank venting, despite being sure the check valves flow well.. I'll rip it all back apart and come up with a fix eventually.
Would or could a clogged canister or valve cause codes 25/26?
Im getting the gas smell really bad under the hood and also with new O2 sensors getting codes 25&26.
Interesting enough, I was getting the gas smell from the back, near the area for the jack. Changed the gas cap and I figured it was fixed. No such luck. I made sure there wasn't a crack in the fuel tank and thankfully there wasn't. I performed the test on the CC as directed by the FSM and my "tank" port was clogged, so I guess fumes could not escape from the tank and would just escape from around the cap? My garage would even smell like gas. Anyway, I replaced the CC with the one suggested here and everything seems to have worked. No more gas smell and the CC from Autozone was an easy fit. Removed the bottom bracket and only used the top. Easy peasy.
Thanks everyone.
