Is this issue one that’s from older LRA’s or is this something that a newly purchased unit would experience?
Nice write-up.
That's a pretty nice (and helpful) DTC table. Is that sourced from the FSM or is it a generic table from teh internetz?
I wonder if simply hitting the filter with compressed air to clean it off suffice to fix this issue?
Semi-related: Your comment about the evap system doing a test overnight makes me think that the flashing CDL light we often get might be a similar overnight test, which is why it happens within 1-2 seconds of vehicle startup. I really wish I understood that system better. It's infrequent enough for me, but if it eventually becomes an issue I will end up taking apart the motor like you did and cleaning it. Now back on topic...
That must be a huge relief! I will say it was a small part of my calculus putting in the factory sub tank that at least I wouldn't have this issue.Filled 32 gallons at my very familiar Costco pump station. At full bore!%# I can't remember the last time I've used the full two clicks on the pump handle with the Cruiser.
@TeCKis300 did you end up running the 5/8” hose to the engine bay and putting the filter there? Or in the location by the filler tube like in the LRA instructions? Does the new 5/8” ID hose come off the factory charcoal canister filter and extend straight to the new filter? What is the double ended 5/8” barb for?
I need to install my LRA soon, and I’d like to use your improvements on my installation. I need to order the additional parts ahead of time.
Thanks for sharing, Cole and YES, Georg, Khris and I appreciate the efforts and patience of the 200 community. We are working on a global update of instructions, fitment kits and fixes.Kudos to @TeCKis300 for sorting this out.
This was timely as I learned that the line from the charcoal canister wasn’t even attached to the evap filter while installing the larger line and new cone filter. Oops.
Watching. I wonder if one of those sack like pie filters to go over the vent filter would help. I wouldn't run a K&N type air filter but I've seen those with a cover pre filter that can be dusted off by hand or removed and washed. On the filler vent, if clogged just reach up and pull it off. Keep a can of compressed air, pc cleaning air, and hit the vent filter with that.
This was timely as I learned that the line from the charcoal canister wasn’t attached to the evap filter while installing the larger line and new cone filter. Oops.
Fortunately not. The main breather coming off the aux tank is a large 3/4" line. Just need to update the filter and adapters to a large bores. All that is behind the fender liner.Does one have to drop the tank to upgrade the breather line?
