Looks like the one!
My trick for doing this project is simple and swap ATF every time I swap motor oil/filter.
- buy a gallon of ATF
- buy one of those twist things that go on the bottle that allows you to slow down the fluid coming out
- buy a funnel with a hose that goes inside the ATF dipstick
I stick a small hole on the handle to help with the pouring. Set the pour to be a nice rate so that it doesn't overwhelm the funnel, then simply walk away.
Note: it's a good idea to measure how much ATF came out of your pan so that you can pour in the same amount. A gallon jug is a good way to measure or old quarts of motor oil.
View attachment 1190952 View attachment 1190953
Hell ya baby, this is a third world country glorified tractor motor doncha know ! [emoji2]OH my, you didn't really put that swill in your trans did you?! Everyone knows that a frail Land Cruiser can not be counted on to live, be reliable, without the highest dollar, specially crafted bouquet fluids in it!![]()
It consists of disconnecting tranny cooling lines from radiator, and installing a drain and pickup hose onto the outlet pipe. Install pickup hose in new bucket of tranny fluid, and put drain pipe in empty bucket. Have your partner watch the hoses to keep air bubbles out and keep pickup hose in the bucket. Start engine, and shift through the gears until the fluid coming out looks clearer. Place vehicle in park and shut off. Reinstall trans cooling lines.
Sent from my XT1080
... ymmv. I saw clean fluid at 14 qt vs 16-18 reported by others.
