Changing ATF fluids
Somewhere
Hello,
I am changing the ATF fluids right now and I don't see how should I drop the pan. Back bolts near the transfer skid plate are not reachable without taking of the skid plate itself. Is my assumption correct ? I wanted to clean the magnets but I will probably just put the ATF back and call it done.
Jorge
Hi, im about to change my atf as well. Sorry i dont have the answer to your question. Just wondering what atf you are using. I know recommended is dexron II but it does not exist anymore. Thanks.
I ended up just changing the fluids without dropping the pan. It's possible to get those three screws out but it was already late. I am planning to do this couple more times so will drop it later. I used mobile 1 synthetic ATF:
Mobil 1™ Synthetic Automatic Transmission Fluid | Mobil™ Motor Oils
This is recommended by this forum and lot's of people is using that.
Jorge
I used a universal joint on a couple of extensions to reach those 3 or 4 bolts, they were kind of a pain but not too bad. I did not take off the transfer case skid plate. This was a 94 with the A442f, might be different for other years.
Remember to put the magnets back in after cleaning everything, I got mine all buttoned up before seeing the 4 magnets sitting on my work bench. Not a good feeling.
I followed the process everybody is using,
  • measure the ATF fluids when engine warm. I went for 30 minutes ride today and measured three times
  • You should buy a new gasket for the drain plug
  • Catch the fluids and measure how much fluid was drained ( I used the old oil jug )
  • Put the same amount back via the dipstick (had to buy new funnel)
Jorge
A) why drop the pan? You won't get all the ATF anyway
B) do the rodney flush and you'll have swapped out the majority of the ATF (search if you need to know more - been discussed many times).
cheers,
george.
Jorge
Measuring is over-rated imo. I drain the fluid and put 4 quarts back in and all is good.
I dropped the pan thinking the wire screen filter needed to be changed, the filter was perfectly clean so I left it alone. The 4 magnets in the bottom of the pan all had a significant amount of slug like material on them (presumably fine metal particles mixed with ATF). I'm sure the magnets could still have captured a lot more metal particles but its nice to know they're good for at least another 150k miles.
My trick for doing this project is simple and swap ATF every time I swap motor oil/filter.
- buy a gallon of ATF
- buy one of those twist things that go on the bottle that allows you to slow down the fluid coming out
- buy a funnel with a hose that goes inside the ATF dipstick
I stick a small hole on the handle to help with the pouring. Set the pour to be a nice rate so that it doesn't overwhelm the funnel, then simply walk away.
Note: it's a good idea to measure how much ATF came out of your pan so that you can pour in the same amount. A gallon jug is a good way to measure or old quarts of motor oil.
I have some kind of weird levels , when the car is cool the level is too high even higher then the "HOT" mark on the dipstick almost it is till where is DEXRON mark. But while the engine is warm and I verified that multiple time the mark is well bellow "HOT" mark. I was just going to put some more ATF as I thought that there is not correct amount of fluids.
Thanks,
Jorge
Are you checking the levels with the vehicle running? Any other symptoms?
Dropping the pan in your garage or drive with a dirty under carriage will most likely introduce more dirt into the transmission than you could clean by doing so. One of the biggest reason all new transmissions don't have a fluid checking stick.
Just change the fluid and drive, there aren't many if at all stories of our transmission give up the ghost. And if so it's probably by doing something really wrong.
I was indeed checking the fluids when the engine was not running. For other noobs as me - the cold means that the engine is started but didn't reach the working temperature. I put half quart more of ATF and I check while the engine was running and it is now just where the top of the "HOT" mark.
10. AUTOMATIC TRANSMISSION FLUID LEVEL
(a) Park the vehicle on a level surface.
(b) With the engine idling and the parking and foot brake applied, shift the selector into all positions from
the P to L, and then shift into the P.
(c) Pull out the dipstick and wipe off the fluid with a clean rag. Re−insert the dipstick fully and check that
the fluid level is in the HOT range.
(d) Do this check with the fluid at normal driving temperature (70 − 80°C (158 − 176°F)).
HINT:
Wait about 30 minutes before checking the fluid level after extended driving at high speeds in hot weather,
driving in heavy traffic or with a trailer.
View attachment 1190952 View attachment 1190953
Everything is easier, when you put the Hood in the Glovebox.
The FAQ link works great too. Just swapped fluids with Rodney flush method mentioned by george_tlc earlier in thread and outlined by snocruiser in FAQ
Easy peasy. Was flowing clean after 14 qt
Unfortunately, it's been "discussed" so many times, when you search for it, you get literally thousands of results that tell you to "search for it".
I'm starting to think the "Rodney Flush" is like the dead walking in China. Everyone knows someone who's seen it, but no one has actually seen it themselves.
Anyone have an actual link to this "Rodney Flush"?
It consists of disconnecting tranny cooling lines from radiator, and installing a drain and pickup hose onto the outlet pipe. Install pickup hose in new bucket of tranny fluid, and put drain pipe in empty bucket. Have your partner watch the hoses to keep air bubbles out and keep pickup hose in the bucket. Start engine, and shift through the gears until the fluid coming out looks clearer. Place vehicle in park and shut off. Reinstall trans cooling lines.
