Center Diff Switch/ABS Light
Truckee, CA
Recently has 4x4Labs install Center Diff Switch light from Slee. ABS light remains on and ABS system not working. Was told by 4x$ to go to dealer to reset ABS system. Slee told me probable damage to ABS system due to 4x4Labs lift install.
Dealer is 45 miles away, anyone with similar problem before I make this road trip?
:confused:
Its possible that they damaged one of the ABS wheel sensors (or the wiring thereto).
Check the top of the knuckle on each side of the front axle.
NOTE: When the CDL is locked, ABS is also disabled. Are you sure the CDL is unlocked?
:confused:
First off, welcome! :flipoff2:
I think you may be a bit confused. The following is my interpretation, which I may be wrong with.
You probably got the Center Diff Switch from Slee. The light inside your dash was always there, but would only have come on if you had put the transfer case into low gear. This is a Toyota 'feature' for those of us in the US market who were deemed too dim to understand how a center diff lock works.
There is a chance that an ABS sensor was killed in the lift install. I think you should look at other possibilities as well though.
There is also the possibility that your diff lock button that was just installed is engaged. Push it -once- (to turn it off) then drive a block or so and see if the center diff light and the ABS light turn off on the dash.
Did they also do the 'Pin 7 mod' for you? It is a modification that allows the center differential control button (that new one) to activate/deactivate the differential lock when in low gear as well.
It sounds like you don't know your way around your 80 very well yet. Thats OK, because if you're willing to learn, then there are a lot of people here who will help you understand it. :beer:
More info....
1) So I have tested the ABS and the tires lock up in loose tire, ABS does not engage.
2) The Center Diff Lock Light comes on when engaged, the ABS remains lit all the time.
3) I have noticed what seems like a drop in power going up hills, around town, pretty much all the time. I can also hear what sounds like a whining while accelerating.
Q: How does one test or determine if Cent Diff remains lock?
It might be worth your time to pull your dash panel off and make sure that the CDL switch is properly attached. I installed ours while NorCalSam was at work and found that the CDL switch was very basic, "plug and play", so maybe something is just not plugged in all of the way. Just a thought, as this is an easy check from the list of possible problems.
Teresa
Is it possible that something else got plugged into the CDL plug which is keeping it enabled all the time, which seems to reason the whining noise your are hearing if locked.
If I remember right, when I did the CDL I labeled wires as I had to un plug certain ones to pull the dash panel off so I could work on it. I just wonder if something is re-installed improperly, keeping the center diff engaged.
Teresa
