Center bore diameter of a fzj80
Thread from the dead but I wanted to log my measurement on my LX450 (1997) hub bore since theres plenty of back n forth on this between 106 or 108.
It IS 108mm. ;-)
FZJ 80 Wheel Specs
Bolt pattern 6 x 5.5”, 6 x 139.7mm
Stock backspacing is 4.5”
Stock Offset is 0”
Center bore is 106mm
PCD is 139.7 (stud)
Stock is 16”x 8” with Offset of 0mm
Just here to prove someone wrong....I have a 1993 triple locked and ordered 106mm rims and they didn't fit. They had to be bored to 108 to fit. Guess that means everyone acting like you're an idiot for asking if it's 106 or 108 are actually wrong. Not all are 106.
Yours must b special
Hub Bore: Ø4.19 in [106.4 mm]
Has anyone Mic'd the actual hub?
Is there a difference from FJ80 & FZJ80?
I was looking at RockTrix wheels, they have 106.1mm bore wheels.
Talking to them they spec my Lx450 at 110mm.
I have had 108mm bore wheels & they seemed to have a little play in them while mounting, but I never actually measured them.
Currently have FJC wheels & they to seem to have a small bit of wiggle to line up the lug nuts.
Okay, did more research:
I have FJC wheels on my Lx450. They spec at 106.1mm
2007-2014 Toyota FJ Cruiser17×8.5106.1mm
1999-2006 Toyota Tundra17×8.5106.1mm
2001-2007 Toyota Sequoia17×8.5106.1mm
Is this what you were looking at?
They look decent enough and < $170 each isn't much costlier than Sequoia wheels + spacers.
Edit- good thing I searched - they would have to be modified -
