CEL Again...Then Off?
San Diego
On my recently purchased 97 LX450, the CEL illuminmated on the drive home from picking it up. I was not too concerned as I was going to drop it off at my mechanics shop on the way home and have him give it a "onceover" anyway. He found a loose vac line, reset the CEL, drove it around a couple of times and the CEL stayed off. That is until I drove it home when it came on again. I brought it back, he checked the code and service bulletin recommended new vacumn modulator ( replaced green one with blue one ). Reset CEL again drove it around, everything fine, right? I picked it up, drove it home, fine until the third use...CEL comes on again. Called my mechanic and he tells me to bring it in again to see if it is the same code. But yesterday while driving it, the CEL went off by itself. Is this normal? Should I take it back to my mechanic anyway? :confused:
do a search for p0401 or EGR, i am pretty sure that is the EGR code; there are tons of threads about it. But for your info, the EGR is a two cycle code, means it won't come on until the 2nd time it is drove after being reset if the problem isn't solved. I had the same thing and I had a bad modulator and VSV, replaced both and the light went off, then came back on, and is no off again on its own. Check those other threads and learn...
