CDL doesn't like to unlock!
Sahuarita, AZ
This problem has been going on for a few months. In my '93 FZJ80 I installed the cdl switch and did the 7-pin mod. All was working just fine until I put 5 inches of lift on. I was getting some front driveshaft vibes, so I removed the front shaft for long trips and drove with the cdl locked. No issues yet. Then one time I made about a 100 mile trip at freeway speeds, but I didn't remove the shaft. I just kept it at speeds that made the least vibrations. Coming back from that trip the cdl would not unlock right away. The dash light was still on and the cd was definitly locked. I tried figure 8's and backing up on the dirt road I was on. Nothing. Went through big ditch to get tires off the ground. Nothing. So I proceeded on down the highway. Then about 15 miles later the dash light turned off and the cdl had unlocked. It has gotten so that sometimes the cdl never unlocks, and I have to pull the front shaft anyway. Even with the front shaft absent(no pressure on cdl) it doesn't unlock. :bang: How hard is it to acces the cdl accuator? Any pictures of what I will be dealing with would be helpful. I have looked and traced wires. Everything seems to be in place. Fluid level is correct. It has no problem locking up, Just unlocking.
You locked the center diff, kept both drive shafts installed, and drove 100 miles at freeway speeds. Do I have that correct?
-B-
-B-
That's the way I read it. :doh:
That's one of the problems with all these great mods like the 7 pin and CDL switch. People don't realize when they should and shouldn't be used. Toyota had it a bit more user friendly, the cdl will only work with it in low and no one can go 70 mph on the interstate in low range.
It was unlocked, but I left the front driveshaft installed for that trip. After getting off the trail and back to the dirt road was the first time it didn't unlock the center diff right away.
I've read that the axle diff locks can be manually unlocked. Is there an option to do this on the transfer case? Does anybody know what wires to check for current at the actuator? Maybe it's an electrical problem and not mechanical.
if you treat your truck like s***, she is gonna treat you like s***
if you treat your truck like ****, she is gonna treat you like ****
GEEE, Your comment helps out sooo much. Thanks for the reply! I actually treat my 80 better than any of the other three cruisers I have owned.
The only times I drove with the front shaft out and the CDL locked was when I was going to be doing extended freeway driving. Otherwise all my local driving was done with both shafts in and the center diff unlocked of course. I didn't drive 100 miles down the freeway w/ it locked. The first time I drove it locked was to get back to the town that was closest to the trail, but it ended up unlocking within a few miles.
I'm just wondering if I did damage by driving with cdl locked and no front shaft. Or if it is an electrical short caused on the trail that day. Or if anybody has had the same problem, and what fixed it.
