CDL Dash Switch Placement
Columbia, MO
I've got my CDL switch ordered from Dan and am considering installing it on the left side of the dash next to the DIFF LOCK dial instead of the usual location. Does anybody have some input on what would be required to perform this? I'm assuming some splicing would be involved to reach that side of the dash. The "stock" location seems to be too close to the passenger's reach if they got "punchy." I guess I'm curious what may happen if I'm running 65 mph and the t-case gets locked. A flip-up switch cover might be cool if it ends up in the stock location...hmmm. :hhmm: :p
I recall reading a post about this but it just discussed the "idea" of placing the switch on the left side IIRC.
Thanks.
--Mark
I've wondered the same thing, what would happen if the switch was accidently engaged at highway speed. I can only imagine the carnage :eek:
There shouldn't be any 'carnage' as long as everything is turning at the same speed. It would probably be sufficient to hit the switch again to turn it off, then hit the passenger thus making it clear that pressing buttons in your truck without permission is unaccpetable and if they can't keep their hands to themselves they will have to walk.
That said, having the switch within close reach of the steering wheel is a great thing. In my '91 it is on the top row of switches in the position closest to the steering wheel, on the passengers side of the wheel.
Cheers
...then hit the passenger thus making it clear that pressing buttons in your truck without permission is unaccpetable...Cheers
I would repeat this step a few times.
...and yes, now that you've mentioned it, I do believe I've read that as long as you're not spinning your wheels, it should not hurt anything. I'll still try NOT to find out.
I've engaged the CDL at 40+mph a bunch of times with no issues, no banging, no grinding, no spinning out of control. I'm pretty sure I've done it at 50+, but its been a while. I just put a small label below the CDL switch, that warns to only engage in Lo. The label is for someone who might borrow the truck and doesn't know what the switch is for, I engage it whenever I want to.
Cheers
I've got mine in the same location for the same reason.
My CDL has been engaged at 65mph on dry pavement.. it's not the best thing do to, but not the end of the world if it happens.. Just keep the truck going in a straight line, as much as possible until you turn it off. Once you stop to turn the car off the ABS will re-engage.
But to answer the OP question, yes all you'd need to do is cut off the connector behind the heater controls, then splice in some longer wires. A trailer harness would work well for this, as it's already colored and sheathed.
I prefer not to alter the factory wires. Does anyone know whether we can order the harness (from CDan maybe) to make an extension? I have got the male side from the hazard switch pigtail, will need a female one for the other side...
You can order the connectors and the wire splices, but the wires are only ~6" long and will probably be all one color. I looked into doing similar for a remote starter and wiring into the factory harness, the splices (wires) are expensive at ~$5 each, and the connectors were $8-10 each. IMHO, I think it would work great just to extend it yourself with wire from radio shack/etc. This is not a critical high current wire harness or anything.
Great. I am for it. I don't mind to extend the wires for the connectors; just don't feel like to do it for the stock one on the truck. Do you happen to have the parts number for the connectors?
Sorry harrydunn for hi-jack your thread.
No, I never looked up these particular connectors, it was the ignition I was dealing with. You can find the p/n on the connector itself, or look in the EWD. You can also use the EWD to find out the correct wire splices that you will need.
I got some connectors and wire splices laying around, let me know if you want some for cheap:grinpimp: Anyway, it is a good idea to extend the CDL and place it next to the big dial locker to have three lockers in one place:wrench:
I suppose I'll just wait until I get my switch to determine whether or not I want to go to the trouble of placing it over on the left dash. I need to get a better idea of what the wiring looks like before I decide if I want to start splicing. What gauge wire would be recommended from my local hardware store?
--Mark
--Mark
I'd just put it in the stock original location, far left top row center console. I"ve had mine there for years and no one has "accidently " pushed it. It's far enough toward the driver side that the passenger has to strech to get to it. Seems like a lot of work for no real benefit.
Pete
You must have some rowdy passengers if there is concern of them randomly pushing buttons on the dash. Maybe you need some new more calm friends :D
Or have an eject button next to it. :hillbilly:
With kids, anything is possible...
The factory gauge wiring can't be more than 18, so any 14-16 gauge would do it, IMO. You'll know a lot more once you actually get back in there and find the thing.
One tip I'd toss out is this is one job that can be done with minimal removal of other stuff, but it's a whole lot easier if you remove more things. For example you can do it with the dash still wired to the ashtray and heater controls, but if you unhook all that and put the dash on the seat, you'll have a lot more room. Same goes with the stereo, a second tip is you can also cut some of the electrical tape that holds that whole harness together, back behind the stereo, which will give you a lot more freedom in switch placement - CDL, hazard, antenna.. this is easiest to do if you also remove the stereo, gives you a lot more room to work. I've been back there many times, and have found that the few extra minutes of removing more things more than pay back in ease of access. HTH...
