CB Radio external speaker
Albany, NY
I have the midland 75-822 CB radio that I can hardly understand what it says. It is not that is it not load enough. But it is not very clear.
I would like to solve this issue with external speaker. Anyone is using external speaker? Is it clearer.
Specifically the $20 - $40 range speakers seems to have some filtering and echo canceling and other dudas. Are those speakers clearer? Not just loader.
TIA
I am using an external speaker. I mounted it behind the sub-woofer grill on my Lexus LX-450 center console.
Where is your CB Mounted? What kind of CB is it?
It may not just be the speaker. It could be your receive quality, antenna, SWR and other issues that are making it sound bad.
How does it sound bad ... in which way? Is it muffled, is there a lot of static, are the voices buried in the noise, is it distorted and over-modulated?
I know a lot about radios and would be willing to take a listen and help you with this when we get together.
FYI - I personally would stay away from electronic fixes,. In my experience, it is better to correct the problem at the source than try to mask it after the fact. Garbage in garbage out as we say in the audio business.
TIA
Rich, as OP said. Midland 75-822.
It sounds like I should just get the Radio Shack 5W $12 one, no electronics, to see if it helps at all.
My antenna is tuned, but will be checked again this weekend.
I don't know how to describe the luck of clarity, but the noise overwhelms the person talking. If there is no noise, the person talking is clear enough to my needs.
However, I don't know why sometimes the sounds is drawn in noises. It feels actually that it has to do more with the transmitter then me.
Oh I just found it in your message:
Yes. Mostly this is when I can't understand what people are saying.
I missed that model...sorry.
I can see why it may not sound all that great. It is using that tiny speaker that doubles as a microphone ... correct? Maybe a speaker will help in your case albeit the receiver section of that radio does have its limitations.
My external speaker is a simple one. I did not really need one but it has better low frequency response and better mid-range .... so when someone has good audio, it sounds really good. I can also usually here long distance or weak transmissions fairly well when they are buried in the noise.
However, this is probably more related to the quality of the receive section on my radio that it is the speaker.
I would be curious as to whether or not the Radio Shack speaker will help. My guess is that it will help a bit. However, it may not solve the problem entirely.
I would be curious if a different antenna like the original Van Ordt Power Sticks would help. I have seen a good antenna change a radio's performance dramatically in the past.
This probably has more to do with a combination of factors .... their transmission is weak ... your receiver has some limitations ... the built-in speaker on your rig is not helping .... and possibly the antenna is playing a role.
How far away are these people you are trying to talk to. Can they hear you OK?
There are a LOT of parts on my truck that not Toyota...:)
PS, your screws for the 12V outlet are not Toyota. They should be black.
I went with a radio shack external speaker. It plugs right into your CB.
Rich, i like the cleanliness of your install very much, BRAVO!
Thank you...it is not complete in those pics. That is why you see wires hanging out by the amplifier.
The 1997 Lexus will hopefully be finished with Stage IV soon....maybe in 45 days or so. I have a final Stage V yet to be done on this truck. It mostly involves mods for the film industry to make this truck ready for an off-road and possibly a reality show that I may or may not get time to produce. Regardless, it will be ready either way. :)
The 1996 Lexus will be done with Stage II within 2 weeks. I will post pics of that as well. I have one more Stage on that which includes a complete engine rebuild and a supercharger install.
Once I get that done, I will post pics of everything.
Sorry, did not mean to hijack here..!! Back to the OP's topic.
Rhyary - You do not live far from me. I would be happy to try some different antennas and a different radio and test your system to see if we can identify the issue. We can plan to do this when Nat is here. You also wanted to drive the trucks with FOR Suspension in them. Let me know when you want to come by.
Rami, I could not hear much of anything coming from my Cobra LTD Bluetooth model due to the mounting position and the firing direction of the stock speaker. I got a cheap Radio Shack external speaker and mounted it up on the bulkhead wall in my Sprinter. It made a big difference for me. I don't hear well due to too many years working with power tools, so I still have to listen carefuly, but it did help.
Ken
I used the driver side stock dash speaker for an external speaker on my ham radio. The speaker doesn't do much to improve the sound of the stock stereo anyhow but is perfect for the two way radio. If you replace the stock door speakers for the stereo, the dash ones are pretty much leftovers.
I just started using the same model handheld 75-822 and so far it works fine. I haven't even had it tuned yet. I purchased a 3' firestick antenna from a local mudder that I hooked up externally. I was worried that the 3' might be too short but it comes in loud and clear. I have not tried using it as a handheld yet with its own antenna and battery pack.
Here are a couple of pics of my setup. I went with this model so I could disconnect when not in use. I also added the quick disconnect for the firestick antenna so I can pull into my garage.
LOL! I have the identical setup other than my little external speaker in the useless cup holder mod.
FYI - If you can straighten out that angle of that antenna, you will get better performance. Also, if yu can get the radiating coils above the roof line a bit more, you will get better performance. However, it may suit your needs as is fine. Just a thought...:)
By better performance do you mean increased range? As far as clarity and volume, I am very satisfied, but all the runs I've used this radio on, all the vehicles have pretty much been in visual range.
This Sunday I researched local Radio Shack stores and there was only 1 speaker available in only one store. I guess it is not very popular item.
The one existing one was missing the bracket and it had the special order invoice for the lady that ordered it. Go figure. I bought it anyway. It was the $25 one. I listen to the $7 external Jonathan my friend has in his LX450 and the sound was better then the Midland 75-822 but the one I got sounds much better. Let me qualify this.
The midland in low volume is fine. So sitting in the car with the engine off, the midland speaker is find. As soon as you started the car and added noise, you have to increase volume on the Midland and the sound got distorted and hard to understand. With the external speaker I can bring up the volume and understand very well. I was trying it when the radio was in weather mode. The weather mode eliminate the CB radio TX and RX issue.
I also bought a small push to talk microphone. The one you put on with a clip. So if it works I plan to stick the 75-822 someplace out of the way and just used the light microphone hanging from some place. This is still needs to be tested out.
I like the non-permanent setup as I don't want the CB radio in the cabin for DD and I don't drive with the antenna installed during my DD mode.
I'll take pictures soon.
Rami
