Catalytic Converter Question
LFD2037
TEXAS LEXUS!
Wax., TEXAS
Seeing another post of someone finally finding their exhaust rattle and it being the inside of their cat busted all up got me thinking. I've had an exhaust rattle since my last off road trip. I banged pretty hard multiple times on some rocks. I've inspected all my exhaust, and heat shields, and can't find the rattle. Other than a dent in the pipe towards the rear, it all seems normal. I don't know a lot about cats but here's what I did.
Warmed truck up to 187*
Checked before/after cat temps
Exhaust pipe directly in front of front cat was ~315
Exhaust pipe directly behind back cat was ~190
Does this tell you anything? From what I've read it should be hotter after the cat(s), not before. I think the guts of the cat(s) is busted. Original cats with 185K. Thanks.
while your catalyst maybe loose and causing the rattling. the few bumps you mentioned did not destroy your cats. having spayed a few cats for some test pieces i can assure you that the catalyst is not overly fragile.
These were not bumps. They were teeth rattle 3' ledge drops onto my sliders/cat protection. Do the temps tell you anything? Thanks!
I had something come loose in the oem big muffler - that would rattle. Replaced the muffler and stuff behind it and all quiet again. This a few years ago...
cheers,
goerge.
Nobody knows anything about cat temps.?
A good rule of thumb for cat temperatures is that the outlet temp be at least 100 degrees Fahrenheit higher than the inlet after it has warmed up to operating temp. A little less is fine but certainly not lower than the inlet temps. My guess is that you have a bad cat. Only way to know for sure would be to separate the exhaust between the cats and look inside.
Yep, smartass, I used google. People refers to 'old' cat systems & 'new' cat systems but never gives hard years on old & new. Old & new differ by how much they burn off and TEMPERATURE. They can range from 300* to 1,600*. Inbound vs. outbound temps can vary from 0* to 500*. Also, most vehicles don't have 2 cats stacked together w/no pipe or sensors between them. . I thought I'd ask people who are knowledgeable about my specific system (ie. year, cats, temps, common issues). Any other brain busters?
My inline cats run about 450-500'F, both about the same temp, but they have 340,000 miles on them and I've been getting a cat inefficiency code recently.
If you wanna test to see if catalyst is all crumbled take a light hammer or wrench/pipe etc and tap on the cat and see if you can hear a rattle. You can even kick it with a tennis shoe. Sounds like it might not be your issue though.
