Caster Shim Dimensions
Okinawa, Japan
Caster Shim Dimensions… Length by Width please… I did a search and came up with a few things and a bunch of links but no measurements… I have a guy here that can make them for free but I don’t have my cruiser here to do my own measuring. (I am in Qatar and the cruiser is in Nebraska) I am going to have him make a 5 degree slope but we can figure that part out… I just don’t know the spring dimensions…
Thanks
dan
Dan,
Thanks for your service to our country!
My buddy Matt posted about shims here: https://forum.ih8mud.com/showpost.php?p=1173107&postcount=104 in my thread about putting a 4 inch lift on my 40.
In it he references Roger Brown, who writes the truck tech section in Toyota Trails. Roger makes shims that people like. It looks like he makes 2 inch wide shims for mini-truck, but says that LC springs are 2 3/4" wide. Looks like he makes them 6" long... Read here: http://www.4crawler.com/4x4/ForSale/Shims.shtml#StdWidthShim
Does that help?
Thanks Guys!!!
sadly both of those websites are blocked by the "Blue Coat" network.
But the dimentions will work fine... sounds like between 2.5" and 2.75" by 3.75" and 6"
hmm i guess as long as both sides are the same that is the biggest issue... I think I'll go with 2.75" by 6" and 6 degree slope!!
thanks guys !!!
Dan
Dan,
6 degrees might be a bit much...
What is your starting caster? 4 degrees might be better. Chances are, you will not be setting land speed records in your Cruiser, so you do not need tons of caster. I think factory spec is + 1 degree.
If you put too much in, you will point the front pinion down, and may put the front DS in a bind while under full/near-full articulation...
Good Luck, and Thanks!
The length is determined by the length of the spring perch, IIRC, the one on my 40 was like 4 3/8" and Roger made them perfect. Now this was for my rear axle, not the front, so maybe the perches are different lengths, but I doubt it.
2 3/4" is definitely the right width. The length is critical, so get a good measurement. I'll measure my front and rear again tonight if someone does not do so before.
GL
Ed
My quickie measurement with a tape measure on my front perches was ~5".
2 3/4" is correct for width. That keeps the shim aligned and prevents it from working sideways. My first set was 2 1/4" wide; they worked loose and broke.
If you use 6" length the thin end will likely bend up with the arc of the springs and not be a problem. Might be a good idea to keep the thick end flush with the edge of the perch. You could also just cut the length down to fit.
If your guy is using aluminum you might as well order a couple extra sets. I've read that aluminum shims don't last long. Not tough enough. Mine certainly weren't.
If you want steel shims, Benz Spring in Portland has them. Got a pair of 2 degree x 2.5" for $17. They've been around for nearly 100 years.
STAINLESS STEEL BABY!!
I thinks 5~6 degree will be ok... I have long front shackles (po's handywork)
here is a link to a pic of my 40... scroll to the very bottom!! my wife's 80 is on the right. In the pics you can see a white clay 40... my wife talked the artist that made it into giving it to her for an anniversary prestent for me!!!! (I married an amazingly awsome woman!!)
http://www.ryuugetsugama.com/gallery/asobi-gokoro/LANDCRUISER/40.htm
how does that tie in with tec... only good pic of my 40's front shackles i have here in Qatar!!
thanks guys!!
dan
Dan, if you get weld-on shims, you will not have to clamp your spring packs and replace the spring pins with longer ones. That made my install much easier
and I just welded the thick end, but you can also weld the sides.
Stainless? Well, I suppose, but not for the weld-on type.
GL
Ed
