Caster question
Oregun
I just finished installing the Skyjacker 2 1/2 inch lift. From reading and researching I came to the conclusion I would need 4° caster shims. I installed them and went to the alignment shop and ended up with left @ -3.0 and right @ -3.7. It seems to drive just fine once the toe was corrected. Are these acceptable numbers? This is with stock manual steering.
No, the #'s are bad. Did you install the shims with the fat end towards the front? Negative caster would offer white knuckle driving.
One more question. I turned the shims around and since I was -3.0 will that now turn it into a +1.0 and will this change my toe in?
not going to change toe in
I can't believe the aligninment place didn't say something about the negative castor.
