Caster question after recent lift
Los Angeles
Just got the OME Heavy 850/863 installed over the weekend. I'm kind of confused though, because when I take the truck in for an alignment at Firestone I dont get Caster #'s in the print out. Do I have to ask them specifically to do caster as well?
Anyway, here are my hub-to-fender height numbers:
Before
DF 19.50" PF 19.75"
DR 20.00" PR 20.25"
After
DF 22.25" PF 22.25"
DR 23.25" PR 23.25"
Change
DF 2.75" PF 2.50"
DR 3.25" PR 3.0"
I plan to add an ARB and possibly sliders during the next year and will likely add spacers up front to achieve a level stance, so I need to keep that in mind as well.
Without knowing my current caster numbers is it possible to determine which caster correction route I should pursue given my current lift height and plans to add weight/spacers? (i.e. Landtank plates, Slee plates, Slee bushings, OME bushings?)
No, you need your current numbers. The bushings are off-set bushings and they add caster. Slee's plates add caster. The Landtank plates (which I have) also add caster up to 7*.
If you don't know where you are starting from then you don't have a target to shoot for.
-B-
Just got my caster numbers from Firestone. Those guys HATE me...:meh:
Caster Numbers:
Front Left = (-1.31*)
Front Right = (-1.47*)
What caster correction product do you all recommend for gaining 4* of caster? That would put me at roughly ~3* positive caster.
Thanks for all your help.
ps- I've read a lot and searched too, so please dont flame me. I've heard that the caster gained is sometimes not as much as hoped for with certain bushings and I only want to do this once
[On a side note, according to the readings, my toe was way out also after the lift. -0.08" Left and +0.26" Right...strange]
Same thing happened to me. Firestone, sometimes sends the bushings out to get pressed in since they don't have the equipment. What you need to do is go back to call Christo or Ben at Slee. Ask them to tell you in which direction the bushing should be "pointing". Go back to Firestone and have them redo the work. Your caster should be between 2* and 4*. NOT NEGATIVE, meaning -1* or so.
I went back 3 times till the got it right.
I am assuming that you have the Yellow bushings included with the kit. Thats what I had
