Caster Correction question
Ogden, Utah
Hello all, I have a question regarding which caster correction to use. I am currently running "J" springs with ARB front, no winch YET, and 30 mm spacer, no armor in the rear...yet.
Here are the specs from the alignment shop...
Left Front: 0.4 deg.
Right Front: -1.5 deg.
Cross Camber reads 0.9 deg.
So, the question is: Which correction would be the best to achieve the 3.0 deg. mark? Slees plates, Slees blue with Landtanks template or OME yellows with Landtanks template?
Also, if it helps my OME lift from MAF is said to be a 3", but measurements have it about 4". I also do have the 3" drop brackets for the control arms.
Thanks in advance, and :cheers:.
WoodyFJ80
Kinda wierd, as the whole purpose of the control arm drop brackets is to correct caster...
That's what I thought as well. But, as I posted before the lift was to be a 3", after install and measurements it is a 4" lift. I do beleive the drop brackets are for a 3" lift.
I could really use some input as to what system to purchase to correct caster.
Thanks
WoodyFJ80
Tough call. Its strange your measurement are that much different between sides. Im not a expert by any means, so maybe just most the numbers that people post are little more close in range.
I would say give the slee blues a shot. You should get ~3* out of them. After that its plates from Slee or Landtank.
Maybe just remove the the drop brakets a go straight for caster plates completely to bring it back to spec.
Like I said Im no expert and others can add/correct me.
Thanks for the inputs, but I am not sure which to do...plates or blues. Hopefully someone will chime in on which to use. also maybe explain why the different specs from left to right readings.
WoodyFJ80
Might pm Landtank, to see what he recommends. FYI, my right/Left caster had 0.5 difference between them. Is there a way that the brackets could be installed incorrectly? I am not that familiar with them...
Hey Fire, thanks I thought about that as well....pm'm Landtank, he would know. the brackets seemed pretty uniform in shape and size, I don't believe there is a right or left bracket. but as we know each LC is differant for some reason.
WoodyFJ80
the cross caster seems a little high and you might check out the front end for play in the wheel bearings or trunion bears as well as anything that might obstruct the turning of the knuckle. I had my alignment done and the tech rotated the tierod clamp out of position and it was striking the leading arm and giving results like that.
Js on a relatively light truck with a 30mm spacer would give something like a 5+" lift. So the drop brackets correct for 3" of that and then you need another two inches of compensation which in my experience is around another 3*.
So replacing the stock bushings with Slee's blues might work well. One concern is what vibrations you might get after wards. I don't have any experience with this kind of set so I don't have any idea of what will happen.
Woody,
How long have you been running your OME springs? If you just put them on recently, you might want to check that you have them on the correct side. You should notice the truck lean a little if they weren't on right, but you would also notice a higher castor spread similar to what you are seeing.
Thanks for the inputs. Landtank, I do have allittle play with the PS front wheel, leading me to think that the wheel bearings need to be done. I did check the clamps and they appear to be at the 10* postion, I think that what I read before on the search. I do have vibs at 30 mph and around 60-65 mph, more on decel, of the throttle.
Gotmud, I have had this set-up for a few years now, and the springs are mounted correctly, I did double check the tag on the srings. I have no body lean. She sits pretty level both long and lat.
Thanks Again and keep those inputs coming, I am leeaning towards the blues and some day a DC shaft from Tom Wood
WoodyFJ80
John Wood
