Thank you. My overheating has been more severe. Since you are local you will be able to appreciate this - get on 580E in San Leandro, by the time I hit Eden Canyon road - truck was at 220o. I got the head back (#1 was burning and leaking slightly, #3 leaking) repaired, and just got it all back together (will post that update next). Was chasing a poor running state that is now resolved by replacing the fuel cut solenoid in the carb with an aftermarket one I got from City Racer. Weird because the factory solenoid still "clicked" but the truck would not run at idle. In any case I need to extend the wiring harness to accomodate the aftermarket solenoid, finish burping it, and take it for a shakedown run.
As for the radiator, I removed the brass unit and put a champion aluminum one back in. I have not flow tested the brass one but aluminum cools so much better. I am looking for every edge.
I have my fingers crossed. Will update on the final situation likely tomorrow due to the showers this afternoon. Georg is a good guy and certainly helps me alot.
The 2 things I hate about this job surround - removing the manifold to begin with, and second getting the %#@#$ exhaust and J pipe reconnected. Seems that I always fight with it forever before it is all lined up to be bolted down. The rest is academic.
