Carb Woes - Advice?
Utah
Website
cruiseroutfitters.com
My 72/40 has been running fine, I took it in for emissions and found out it wasa running way rich above idle (9.89% CO at both speed tests).
Take a look down the carb (~75' era carb, Jim C built several years ago) with the air filter off, and anywhere above idle, it is dumping fuel out the primary venturi.
Vaccum @ idle: ~17.5 in Hg with less than .5 in Hg fluctuation
Compression ~135 psi per cylinder
Primary Jet 1.2mm Primary Idle Jet .55
Secondary Jet 1.8mm Secondary Idle Circuit .80
Power Valve Jet .55
Valves .010" Intakes, .014" Exhausts
Trying to leave for Moab in the next couple days, Any suggestions where to look?
A likely culprit is the air correction jets and air vent holes in the emusifier tubes are plugged, dumping straight fuel instead of air/fuel mix into the nozzle. Tends to happen if the carb hasn't been run in a long time.
You can try the Oklahoma rebuild:
Hose down the inside of the carb (and inside the fuel bowl via the angled brass tubes) with spray carb cleaner and let it sit a couple of minutes.
Start it, rev it up to 2500 RPM and hand choke (yes, with your hand over the air horn) it until it stalls.
Repeat as necessary.
This pulls a high vacuum inside the carb and pulls fuel out of the bowl though the air holes and if you get lucky it will clean them out.
If that doesn't work you can take the top cover off and run a tiny wire through the holes to open them.
If that doesn't work it is time to dip it and put a kit in it.
Pin_Head said:
A likely culprit is the air correction jets and air vent holes in the emusifier tubes are plugged, dumping straight fuel instead of air/fuel mix into the nozzle. Tends to happen if the carb hasn't been run in a long time. ..
Thanks for the help!
Is the air correction jet an actual replaceable "jet"? It is easy enough to pop the cover of the carb off, I have done it a couple times.
So I should remove the emulsifier tubes and clean?
There are 3 air vents for 2 for the the primary and secondary. The most likely culprit is the one that is on top of the emulsifier tube which is part of the nozzle assembly. You can remove it w/o disassembling the carb. Just don't drop the screws.
The one for the slow jet is less likely to be a problem as it mixes the fuel with air for the "transition slot" which is just above the throttle plate. This may be plugged and dumping fuel too, but it is harder to see.
Thanks... that gives me something to loook for. The fuel is dumping right out of the primary nozzel, enough that it puddles up on the butterfly if you shut off the rig at a full throttle... Hopefully I can pull the nozzle off and do some cleaning tomorrow afternoon (finals until then :()
Thanks again and any other suggestions are appreciated...
Hey Kurt, I'm with Pin-Head on this one. From what we went over on the phone earlier, and the stats you've posted now, I think you've pretty well ruled out the idle circuit. So the next issue becomes what is happening when you first come off idle.
So, as I asked you on the phone, what is the vacuum reading at the point where gas is puddling? I'm also wondering if perhaps your power valve is stuck open, bringing gas to the emulsifier around the primary jet. Have you messed with the routing on it lately? :confused:
If its not sorted out by Wed, rest assured I will have a first-hand look at it. :)
Bring a vacuum guage and a timing light with you. I've got a dwellmeter and tach packed with me. ;)
Dude, you rule.... I will buy you plenty of booze in that case....
To answer your questions... no changes were made to the system since it passed IM 9 months ago. At anything above idle, I am getting ~18 in Hg.
I put a new powervalve in this afternoon, but I am not sure that the power valve piston is working correctly (mabey the spring is too compressed?). Other than that the carb has essentially all new parts...
Damn, there is a reason I send carbs to experts ;) IH8carbs :D
Though this whole experience has gained me some first hand carb knowledge... prior to this I had never really done troubleshooting on carb systems.
Ideas???
This is a USA carb, right? The USA versions I have seen have a line on the top cover that connects to the VSV, which decides whether it should be open. (First generation electronic carb). I thought about this, but I discounted it as there are plenty of people out there with desmogged 2Fs running around with the power valve always open and they aren't having trouble, except poor fuel economy.
You could try pulling the vacuum line off (I think it is marked port 10 on the casting) and see if the problem goes away.
Mark: What do you do with the power valve when you throw away the VSV? It takes so little vacuum to operate that it seems like it would always be on if you just connect it to manifold vacuum. If you just leave it disconnected it won't be there when you need it.
Hmmm... The only vacuum line on my top cover is for the choke pull-off diaphram (shares vacuum with the power valve piston).
I will have to snap some pics tomorrow (after 4 hours of Strengths II & Maechatronics II finals :()
Pin_Head said:
...You could try pulling the vacuum line off (I think it is marked port 10 on the casting) and see if the problem goes away...
I did pull this line off, I played around with plugging it & leaving it open... Seems that I could hear the power valve piston opening and closing... I "think" that the power valve is normally closed when little vaccum (idle) and then opens at higher throttle... mabey I need a stronger spring? Or a different carb? :D
One more thing... what should my ported vacuum advance (to my distributor) be pulling (vaccum)? Obviously 0 @ idle, but should it read 15+ in Hg at full throttle?
Just thinking out loud now (should be studying).. Is it possible my choke pulloff diaphram is leaking? Thus making the power piston always stay in the down position? If this was the case, the power valve ciruit would always stay open, and dump that extra fuel... Though this doesn't explain why it runs great (emissions wise) at an idle...
You should be studying for your finals instead of staying up late fiddling with your carb. :flipoff2:
The way it works is: No vacuum = closed.
A tiny amount of vacuum = open.
NOn-USA carbs operate the valve from carb vacuum, probably ported vaccum, so I'm betting that it uses a stronger spring.
My understanding of these power valves is that they were designed to lean out the mix during cruise conditions so that they could better achieve the corporate fuel econony standards that we just established in the mid 70s. The auxilliary jet is small, so when it is open, basically it just makes te total main jet area the same as what was used before fuel the standards. It was an attempt to electronically control the mixture to provide for better fuel economy and still have the power needed for WOT situations. Having it open all the time is like having an early carb with a larger main jet.
BTW, we haven't even had midterms yet out here on the left coast.
I am trying to check the same problem with the power valve. How can you check that the power valve is functioning? How does it get its vacuum from the top of the carb when the hose is connected to VTV and choke breaker?
I am running to rich and trying to locate the source.
The power valve gets its actuation vacuum from the VSV, not the choke breaker (at least on the ate 70s ones I have seen). The VSV vacuum comes from the manifold and it is controlled by the "computer". Pull a vacuum on the hose and you should be able to hear it click. If you have this line hooked to any other vacuum source it will always be open because it takes very little vacuum to operate it.
I have my carb off now and when I cover the two holes at the bottom of the primary barrel (small hole and the bigger hole with the bolt) I can pull a vacuum with my hand vacuum pump. I should just be able to pull a vacuum on that top line that feeds it and it should hold? By having to hold my fingers over these holes at the bottom does that mean the power valve is leaking?
Kevin,
You are fine. Yes, cover the large bolt hole on the bottom of the carb, and the smaller drillhole inside the secondary. Pump up vacuum on the center top fitting. Some leakage is normal, but it should hold briefly when you pump it. If it does leak vacuum, it is not the PV that is leaking, but rather the power piston. The PV is a separate piece inside the carb, actuated by the power piston.
