Carb Rebuild......Instruction needed
Cincinnati, OH
Guys,
My mechanic friend was supposed to rebuild my carb using the keystar (sp?) rebuild kit and the haynes manual but he's no longer an option so I'm goin to dig in and get r done. Problem is I have zero carb experience and no instructions with the kit and I was wondering if anyone had any instructions layin around to scan/email. This is for a 77 fj40.
Thanks in advance,
CHase
Jim C or Mark would be the thing to do if my situation was different. I fronted my mechanic friend the $$ for the rebuild b/c he was in a jam but after 2 months of stalling he is now unable to be reached. So basically my carb budget has been exhausted. :mad:
The factory instructions aren't that detailed and mainly contain specifications for float level and other things that usually don't need adjusting when you rebuild the carb.
The main thing is to pay attention to what goes where when you disassemble it. Videotape the disassembly and tape the tiny parts to a cardboard sheet and make notes of where they go.
Mnimally disassemble it just enough to separate it into the three main parts; air horn, bowl and base. Only disconnect linkage from one end. DO NOT remove the butterflies from the shafts.
Clean in carb dip overnight. Spray cleaner won't cut it. Don't dip anything that is not metal. Rinse thoroughly and blow out all of the tiny passages with compressed air or spray cleaner to verify that they are clear.
Reassemble in the same order you took it apart.
It isn't rocket science, but it will spank you if you are not paying attention because there are two of most parts that look the same but they only go in one way.
if you can't afford teh $25 for the carb rebuild kit, you're gonna choke when you see what it costs to get one rebuilt ;)
bk
Do what PinHead says. I have done several of the 73-74 carbs and they have all turned out fine. I disassembled mine on an old white bath towel which seems to catch parts well. The kit should have an exploded parts diagram in it.
Berryman's, compressed air...you know, like PH says.
Ed
I got a rebuild kit the other day, pulled the carb and did some minor disassembly. Then I went down to the Friendly Local Auto Parts Store(s) [FLAPS] to get the carb dip.... and they were out! Just been recalled from the manufacture. Three stores, same story.
Is this bad karma, or do I have a big L stamped on my forehead?
