carb options
wenatchee
Im working on rebuilding the engein in my 1970 fj40 and I was wondering what would be a good carb to get so I could get a little more hp out of it. and what are there for valve covers out there? I've looked and didnt find to much.
I would stick with the Toyota carbs. I know people who have changed and regret it
An Aisan 38/38 is a good setup. It flows much more than a little weber 38/38, slightly more than a holley 350, and it fits perfect (no leaky adapters).
what are there for valve covers out there? I've looked and didnt find too much.
The 79-80 2F valve cover is the bestest. Leakproof aluminum and a thread in oil fill cap, so it will never blow out, even in event of a crankcase backfire.
so should I just rebuild the stock one? or throw it and get a 38/38 and what does 38/38 mean? thanks for any and all help, this if my 1st cruiser so I'm still new to most of this stuff.
The numbers in Weber, Solex, and Aisan nomenclature refer to the throttle bore size. i.e. the aisan SD40 is a single barrel, downdraft, 40mm throttle carb. The DD38 is double barrel, downdraft, 38mm throttles.
The stock carb is pretty good, but can be made even better with some tweaking. Also, the ported vac fitting for a vac advance distributor needs to be drilled & pressed in.
try a Quadrajet......mounted directly ontop of a 350! it works for me and you can not only throw all that Webber/Assin whatever in the trash or ePay but you can also readily find someone who can work on it. I'm not biased, only experienced ;)
