Carb Options
I have seen that people have rochester and motorcraft carbs on their fj40's I have a 71. Does anyone know the model #s to these carbs and if they will fit my 71. The only reason I would consider these other brands as Im sure everyone is going to tell me to stick with Aisan or weber, is the price. My pockets have no depth, just lint.
Thanks
:banana:
I wouldn't trade a rochester for an aisen for sure (I pitched mine as soon as I could). Did anyone respond to your query about putting a 79 Aisen in your 71?
Well, you can have your stock carb rebuilt for about $250-$300. I'm currently getting all my ducks in a row to do just that. I've found that with my Carter AFB (similar in design to an Edelbrock), the main trouble comes in off camber situations. The truck wants to stall as fuel spills out of the bowl. I know there are a couple tweeks I could do to help, but I also don't think I need a four barrel carb to dump massive amounts of fuel into my engine. It's a truck. I don't care if it goes slow.
You can and should do a search to read pages of info on the stock vs. non-stock carb thing, but I think it's generally accepted that the stock Aisin will perform better off-road.
I've got a weber...not sure of the number....that has an electric choke. Been sitting in the garage for a couple of years, but came off of a running '73. Took it off when I put in a different engine. PM me for price if you're interested.
Would you pay $20 for a plate of dog shiit when you could get a steak for $30?
Can I get the dog shiite for $30?
Then I'd be interested.:)
carb
Yeah, seems like a PITA. Chances are Im going to send it off for a rebuilt at marks off road or something..
Thanks
What I would do is sell the 79 to someone who needs it and get a simple rebuilt "Non-USA" vacuum advance type carb and a "nonUSA" (early) vacuum advance distributor. I'm sure Mark or Jim could fix you up.
The Motorcraft carb works great on and off road. I'm pretty sure it's the 2150 you want. I got mine for free and the adapter plate for $5. Then you have to fab up a linkage for it and find one of those little universal air cleaners. It's a bit of a pain, but I didn't have any carb so I went the cheap route and I don't regret it.
In your case though, it almost sounds better to trade your 79 carb and find an older Aisin you can use. I'm sure Mark can hook you up with something that will work.
I'm running a 77 carb on a 73, works great, maybe not perfectly dialed in, but works far better than a Holley.
Unless the carb is just trashed completely, get a good rebuild kit, Jim Chenoweth has the best FJ40Jim above and clean it up, not very tough, and you learn your carb that way.
When going to a newer carb, air cleaner fitment is an issue. I already had a 2F valvecover, got a 2F aircleaner, but the deminsions of the 1F intake are different. I had to make custom brackets for the air cleaner to bolt to the valve cover and still line up with the top of the carb. Easy to do though, and works good.
I'm sure if you keep your eyes open long enough....something will turn up here in the for sale section. Or post on the wanted section someone is bound to have what you are looking for. Ebay is another good source to get it at but it's a higher price venue.
I had a rochester and ran fine for a while and then for some reason or other it started leaking and dieseling after you shut it off. If I had to do it agian I would definately not go that that route ever again even if it was free-bee.
Between carbs and ignition systems, you will find on this board that everyone has a different opinion.
I personally have had 3 Aisans on my original F and my 2F, and am now running a Holley 350. I had to do some tweaking for the offroad performance, but am very happy with it. In fact, I'm taking all three Aisans out to Tim Hill next weekend for some tradeout, because they are wasting space on my shelf.
Decision
:banana: OK guys thanks for the input. I have decided to rebuild my carb (again). This time I will do it right and soak the carb over night etc.. Thanks Degnol for the info.
Later
