Carb looking glass level
Tommy Shumpert
Spring/Woodlands Texas
I saw somewhere and I can’t find it...
My carb looking glass level is below half. I saw somewhere where it needs to be in the middle.
What setting, and which direction do I adjust it to get it to middle of glass?
Thanks
If it ain't broke don't fix it.
Once you start adjusting the float for the needle valve you open up a can of worms.
Are you having problems with it running out of fuel? Is it running below the bottom metal tab in the sight glass? The normal level should be between the metal in the sight glass, not really in the dead center.
To adjust it you need to pull the top cap off of the carb and adjust the small tab on the float. It is a pain.
