Carb identification help needed
Indygbd
Indiana
Looking to identify what type of carburetor this is. Also what year is it for?
Thanks.
Looks like it's stamped January 11 1972
I think it's a bit later than 71. 71's have the throttle cable setup. This appears to have the linkage style throttle attachment.
The 70-71ish carb bowls are cast a bit different than the later mechanical secondary carbs
73-74ish
70-71ish
Thanks. My 72 project does not have the original carb. Trying to track one down and I found this one.
your 72 would have a linkage from gas pedal to the carb correct? @Indygbd
As you are likely aware of, it's been stripped of a few parts.
-accelerator pump arm
-choke pull off/Choke breaker
-choke cable bracket
-fuel return banjo
-you'd need what the book calls the "1st idle connector" it actuates the arm that controls the weighted "high speed valve"
Then I guess Indygbd will need to remove the stud in favor of a cable grabber dohicky:hillbilly:
Also a bracket to hold the throttle cable and spring tensioner bracket. At one time Mark's Off Road had spring tensioner re-pop's.
Pics of cable style carb
Link to spring tensioner bracket measurements in case needed: Baseline adjustments on a Trollhole carb ('77)
Somebody sawed off the choke cable connector from the air horn linkage. Never seen that done before. :-(
