I am battling a vacuum leak at the carb heat insulator where a previous owner used a grinder to remove the gasket material from the heat insulator. I can’t get a good seal because of the slight dishing of the sanding marks.
I know it looks like gasket material left behind. I have no idea what the tan stuff is if it’s not gasket material, but a razor blade won’t touch it. I soaked the insulator in my parts washer hoping the tan stuff would absorb and lift a little. Nope
So I tried running it as is, but I still get a vac leak on the primary opening where the phenolic is visible:
I don’t want to try to sand the remaining tan stuff off because I think I’ll just make stuff worse. I know I can but a new insulator, but I want to see if I can get this one cleaned up first.
Any ideas?
Any ideas?
