Carb fuel level
Roseburg ,Or
I’m stumped and looking for some help. Backstory:
74’ FJ40, vac retard dist with Pertronix and Trollhole carb. When I bought the cruiser it had sat for a few years, had a knock-off Weber carb and Pertronix half-ass installed with the dist off a tooth.
When I first got it, it fired right up and idled great; the problem was a nasty miss and backfire through the carb with any load put on the engine. You could free rev it, but in gear it would miss like crazy and was undriveable.
I decided to spend some money and update the carb and Pertronix, while doing the routine tune up. Valves ran, new intake/exhaust manifold gasket (forget the brand; but it’s what was recommended here several times), restabbed the distributor. Vacuum at 18”, new plugs, wires, cap, rotor and fuel filter.
Forgot to mention the PO removed the mechanical fuel pump for an Airtex electric pump.
Fire the truck back up, take it for a drive and it’s the same problem. Backfires through the carb and can’t get out of its own way. Check the plugs and they’re lean.
During a drive tonight I shut the truck off when it missed and pulled over to check the sight glass; less than half full, but not by much. Revved the engine to about 1,500 rpms and I can no longer see fuel in the glass.
So, I replaced the fuel pump with a Holley 1.5-4psi at 25GPH. Same problem. Haven’t hooked a gauge up to see the actual pressure because I assumed it was at the max and you’d regulate it down.
Is it possible the electric pump doesn’t flow enough GPH to keep the bowl full?
Any help would be much appreciated!
I would think 25GPH is more than enough. Is it possible your gas tank is getting vapor locked. Maybe try it with the gas cap cracked open a tad.
Or is something in your fuel tank restricting the pickup tube. You could pull the tank drain plug and see what comes out. Maybe even shoot compressed air into fuel line to blow back any crud that may be pre-filter. Add fuel back in tank, drain again, see if dislodged gunk comes out. With tank drained, pull sender, sneek your smartphone camera in sender hole for some snapshots of tanks innards.
Do you have a fuel return line? If so, did the PO have it hooked up backwards?
Maybe a piece of grit broke free from the fuel line post filter and is blocking your float needle.
You capped the dissy retard pot correct?
No return line and I should add that I’ve bent all new lines and replaced all the rubber.
I bought the trollhole carb used from a member, knowing it never ran right. Pulled the carb down and cleaned it twice, blowing out every orfice. Initially, the butterflies interfered with the carb spacer, so I had to do a small port job to get everything moving freely. Even so, with the paper clip test, the secondaries aren’t opening.
The issue is that it’s the same issue with two separate carbs. The weber hauled ass for about two seconds before falling on its face, the trollhole doesnt have near the power, but still falls on its face in the same time frame.
I’ll pull the lines next and check the tank to make sure there’s nothing causing a block; I put a clear fuel filter on for this reason and it’s very clean. I’ve also ran with no cap on the tank trying to rule out vapor lock.
Appreciate the advice. Once I check the tank, I’ll report back.
Original 44 year old tank?
It is. I guess I overlooked this as being an option because of how clean the clear fuel filters have been. I’ll look further into this over the weekend.
On a side note, I picked up a complete 78’ 2F a few weeks back for cheap and would like to send that carb to you for a rebuild. Plan was to wait until I got the gremlins worked out so I didn’t mess it up.
Like I told someone at the Bakersfield rally two weeks ago, start off by blowing air back into the tank. May give temporary relief for a failing pickup.
Blew into the tank with air multiple times. Each time it made a sound almost as if there were a check valve; fuel cap removed.
Decided to double check vacuum and it’s 16”. I’ve got to have a leak somewhere, but for the life of me can’t find it. Maybe it’s time to have the manifold pressure checked?
I have to admit that the cheap paint can smoke tester was well worth the effort. I found a pesky leak at the charcoal canister where I never thought to look.
Also, where is your fuel pump mounted? It needs to be near but below the gas tank. Inline pumps are strong pushers, weak pullers.
Below the tank, on the frame. The PO had it on the firewall. Good idea on the smoke tester. Thanks
Have you retorqued your manifold bolts?
When you installed the new Manifold gasket, did you bolt them together and have a machine shop plane them? I’ve ran across FJ40Jim & MarkW posts where they’ve said Fel-Pro manifold gaskets are the best. Big Flame rings.
You checked valve lash with the engine running correct?
:beer:
:beer:
Remflex gasket, retorqued, and sprayed with starting fluid to check for leaks with the vacuum gauge hooked to the brake booster port on the manifold. I did not have the header/manifold milled, but I definitely will when I pull it back down.
Any harm in using the intake manifold off the 78’ 2F I recently picked up?
