Car Wash Stalled Engine (killed)
Washington, MO
I took the LC to the local spray and pay and decided to clean some of the dust from under the hood. I purposefully stayed away from the distributor area and the top of the engine.
I was mainly concentrating on the firewall area and the insides of the wheel wells down low. I don't know what I got wet, but when I went to start it, it just kept turning over either no spark or no fuel delivery. It never smelled flooded.
I pulled all electrical plugs apart and checked for water, everything looked dry. After 20 minutes, the engine started and would rev, but I didn't have any power. After an hour of of drying off everything I could reach and open, it finally started and I was able to drive home.
Does anyone have any idea what the heck I could have gotten wet? In retrospect, this is the first time that I turned off the motor while cleaning, I don't think I do that again.
This is pretty common. Once dry your rig will be ok. If you do some searching you will find alot of info about the same troubles and some options you may want to try in the future. When trying to clean your engine bay.
If you decide to take your rig wheel'n and have to cross some water you might want to consider your distributor.
:beer:
For whatever reason, I wasn't able to get a suitable "car wash" answer to pop up when I searched. I read all about water proofing for water crossings and water crossings, etc... I couldn't find the car wash subject. I'll do more searching. Sometimes I think I'm not the best searcher, I thought car wash, cleaning, and pressure washing would be a good search. I guess I'm being too logical.
Pretty common problem. 1000 psi will put water in places you don't want.
When I was 15 I went with my 16 year old cousin to clean his engine at 9:00 pm at a dark truck stop presure washer. We ended up calling my step father to bail us out. Water in the distributor. Of course there was no electronic nothing on that 1975 Olds Cutlass.
Same thing happened to me at home the other day. I was de-greasing and hosing off the engine while the fan was out for the blue fan clutch mod, and at first, no start, dry, then start and rough idle with code 0306 - misfire on cylinder six. Then clear code, dry some more, and it's all good now. I suppose there's something I should do, but the easiest thing is to skip the annual car wash, I suppose. Tan colored cruisers have a use after all...
I wish I could figure out what I hit to cause the problem. It's something on either the right side or left side wheel well. Or on the firewall. All of those connections were dry when I took them apart. There was 1/8" water standing on top of the coil below the lip. I'm puzzled.
There's hole in the distributor (not on the cap) for breathing purpose. You need a small mirror to see the hole since the hole is facing straight to the ground. Put a rubber grommet on that hole, sort of like a small extended hose. It needs to be heat resistant and has to stay on the hole forever. After you do that, go try your car wash again, if the truck still stalls, you've got issues else where. I do not know if Permanently closing that hole (with RTV) would cause any issue. Although mine is like that, has been like that for several years now and I don't have any problem.
Give that a try :cheers:
You prolly pushed alot of water into the coil there. Water and low voltage to high voltage transitions happening several times each and every second definitely do not work well. Avoid high pressure washing with water in the future. HTH. :cheers:
Biggest culprit seems to be the MAF connector on the air intake hose top - right above the right fender.
DougM
DougM
Not really "wheel well" level but it could still cause problems. My guess is still something with the coil. Heck with enough pressure there you could have even upfilled the boot to the wire with water. Either way, let it dry and keep it dry. HTH. :cheers:
A quick fix to get you going is to spray some WD-40 over the distributor, this displaces the water and after a good ride the heat from your engine will dry everthing off.
There was a post on Safari or some Aussie board about coating your "gas engine" distributor with heavy grease just because stalling while crossing the Jardine River almost ensures that you will be crocy lunch if you try to walk out.
Anyhow the WD-40 works, and if you are curious about the plug wires and all, just spray some water over your engine while running and "dark" if you see sparks or flashes you just may head of a problem...
Interesting. I washed my engine bay few times in the past few months to get rid of salt accumelation from the winter. I made sure to be away from the track so no high pressure. One time it ran rough for few minutes. Othewise no big problem to report. Sounds like I just got lucky.
I normally triple bag and tape up dist, carb, air filter area. This way when I do get high pressured water inside one layer of plastic, it would take sometime for it to get into the next layer. By that time, I'm already finished rinsing. Works great everytime!!!
WD40 works great to get rid of water too!
I place a tube in the breather and conect it to my air box filter .. make another ole and route a tuve to the cabin .. just to make a positive pressure in the Distributor ..
