Can’t Wire TPS to TCU – No Diagram, Is This Even the Fix?
Saudi Arabia
Hey everyone,
I’m stuck and need some guidance:
• I’ve swapped a 3RZ-FE into my LJ71 and kept the original A343F trans + 2L-TE ECT ECU (PN 89530-60050).
• The TPS on the 3RZ-FE is plugged into the engine ECU, but the trans ECU never sees it.
• Without TPS input the trans skips 1st gear and shifts poorly—so I know I need to feed the VTA signal into the TCU.
The problem:
• I do not have a wiring diagram or pinout for the transmission ECU.
• I don’t know exactly which pin on the 26-pin TCU harness is the TPS input, or how to safely tie it in.
Questions:
1. Has anyone got the official pinout/diagram for the 2L-TE ECT ECU (89530-60050)?
2. Will wiring the 3RZ-FE TPS VTA to the correct TCU pin actually solve my shift-timing issue? Or is there something else I’m missing?
3. If direct wiring is dangerous without the diagram, what’s the recommended workaround?
Any help, even a photo of your TCU plug with pin numbers, would be hugely appreciated. I really want to avoid going to a standalone controller if possible.
Thanks!
Hey! Im in almost in the same boat but im using a 2jz but im having issues with wiring it up to work with the 2j motor may I ask how you did it?
Also if you haven't got the pin out yet I m8ght have one that'll help
Appreciate the input. Honestly, I suffered for a year trying to figure this out before finally doing a manual transmission swap as a last resort. The difference is night and day; the car feels completely different, and the torque improvement is massive.
By the way, I do have a rough wiring diagram for the TCU, but I can't completely verify its accuracy. One big tip I learned through all this: if you crack open most Toyota ECUs or TCUs, the pin names are actually printed directly on the PCB inside.
