Doing my first Birf service. I found the beginnings of birf soup from a bad seal. the steering arm required A LOT of BFH to remove and now I cant get it back on. Any advice?
If you honestly think your studs are tweaked, I would HIGHLY encourage you to NOT reuse them. Order new studs. Nots sure that’s a part you really want to persuade back into shape after it was persuaded out of shape - if you know what I mean.Yeah its the knuckle studs are tweaked somehow. I took the knuckle off and tried to put the steering arm onto it and it wont go on and I can see the studs are touching the indside of the holes in the steering arm at funky angles. It's so minor it seems like the arm would still go on but it wont. Im gunna try some minor de-tweaking on them and see if it helps otherwise maybe I will fix the problem by buying hellfire knuckles lol
@NLXTACY also sells a nice stud kit complete with the e12 socket. 80 Series OEM Lower Knuckle Stud and Hardware KitUgh you mean like be intelligent so I don't have some crazy issue later?? Well I guess. Cruiseroutfitters it is.
Thanks team.
A
IC. @NLXTACY are you going to do any more of the exploded view axle posters?
Yes. Just after Halloween.
Can you make some with the design on the front?
Sweet! And wow you respond fast . . .
On the front of the poster?![]()
DOH! For some reason I thought you guys were talking about the shirts![]()
Can you just reverse the image on the front of the shirt so I can read it in the mirror?I have to do another run of SOME sizes of shirts. I’ll consider doing a batch reversed.
