No rush. Just looking forward to seeing the final product. thanks for the update though!
factory horn on frame is retained. you will have to drill one hole in the frame for the winch bracket - only modification to the truck.
winch plate will bolt from the 1/4" thick winch plate, thru the frame, and thru the 1/4" thick bumper bracket riser on the other side of the frame. it will also attach to the frame crossmember in front of the radiator, so it's pulling from 4 points on the frame.
will there be instructions with the bumper? Just to make sure no mistakes are made during installation
The steel pieces that are bent and cut in the package would have instructions right? I dont have any kind of welding equipment so I'd have to go to some kind of shop to get it done
bamachem said:Most definitely. CAD sketches of how they fit together, etc, step-by-step text along with pics, etc. Just no scale drawings with dimensions, etc. If someone wants to copy it, they'll have to get their hands on one to copy the dimensions, just like they would have to do for an ARB, etc...
How much my friend, raw steel (no paint or powder). What sized winch you be using? Thanks
