Cannot engage 4x4
Uganda
Hi guys, as the title says, I press the 4x4 button and nothing happens.
Here's what happened. Pressed the button, heard a funny relay sound and then it went all quiet. The 4WD light on dash was not there as the whirring of the motor engagin the 4x4.
I have checked everything, all connections are good, no broken wires, all fuses are good and working.
I even swapped the transmission relay box from another car and still nothing. (I don't know if that box was working in the 1st place)
I then noticed that if I shift to low range the relays on the transmission relay box click but still no light and no whirring of the motor. The 4WD button does nothing.
I also tested the pins on the transission relay socket and I get power on some pins when I press the 4WD button on the dash.
I have run out of ideas on what to look for so any help will be appreciated.
Cher!
Based on the fact that yours is different from ours, I'm only going on a limb here.
For the US 80s, if you engage the center diff lock, which needs to be engaged before you can lock the rear or front, and the light doesn't come on, the lockers won't actuate.
I've seen this happen in my 80, I heard the center diff lock but the light didn't come on so then neither the rear nor the front lockers would actuate.
This could be totally different for you and I apologize if it leads you astray.
You might want to give us some more background on your car.
Of course I might be wrong, since I don't know every little aspect of the 80 series everywhere around the world, but as far as I can tell the 80 series came with a full time all wheel drive system.
I never heard of a single one in which the 4x4 could be engaged by a push of a button. All of the ones I know have a lever which controls the transfer case and you can select the traction mode you want, be it converted 4x2 models too.
Are you really sure you are not referring to the central differential lock button here?
I think pre 1992 came in 2x4 with selectable 4x4. I have free wheel hubs in the front. But yes you could define the 4WD switch as the cdl switch. The button is exactly where the cdl switch is and is labeled 4WD and in the dash I get a greed 4WD light when it engages.
Had a read at the link posted and the problem is not just the light but the actuator motor does not cycle.
