You can run into problems with too much caster, but I doubt that caster plates would cause a problem with a 4 inch lift. The main problem with too much caster, is that you reduce your contact patch in turns, so you are more likely to slide out in high speed turns or on slick surfaces, It also increases wear on the inside and outside edges of the tires.
