Can I use the drive shaft screw to snug down harmonic balancer in 22re?
I smell Mons Venus!
EDIT: Can I use crankshaft bolt to snug down the harmonic balancer?
Hi, and thanks in advance.
I've been trying to get this harmonic balancer in my '92 22re, and am about 1/8 (or less) an inch from being on the crankshaft completely. I can thread the 19mm drive shaft bolt, and want to make sure this isn't going to mess with the drive shaft.
I've been using a rubber mallet lightly on balancer and am concerned about using a BFH on the balancer pulleys. Should I just use the hammer?
__________________
1992 Toyota Pickup, base, 22RE, 5-speed, 137,000 miles.
__________________
Stop pounding on the pulley. You will mess it up. Use the bolt to press the pulley the rest of the way.
