Can i use my rig normally?
Peru
Hey guys, I have a question about my Land Cruiser FJ62.
I recently bought it and while inspecting the chassis I found the following:
There’s a reinforcement plate welded onto the passenger-side frame rail (under the front seat area)
The weld is continuous
Just before the plate, there’s a very small weld bead, like it may have had a crack that was repaired
Driver side frame rail is untouched/original
This is only present on the passenger side
Additional info:
There’s no visible rust on the frame, and no other areas of the chassis show rust issues
Body lines are straight, doors align and close properly
No visible misalignment in the body
Floor pan from the inside (with the factory ribs) looks intact and not deformed
Wheels are centered (no axle shift)
There are some dents/warping on the lower part of the door and rocker panel
The truck is running 33” tires
My question: Have you guys seen this kind of repair on FJ60/FJ62 frames? Are cracks in that place of the frame common in FJ60s? Is from frame fatigue/off-road use? It's still off-road usable?
Appreciate any input, especially from those who’ve dealt with frame repairs or similar cases
Thank you in advance Folks!!
Image of the plate and one of My rig
Obviously that is a repair of some type.
Since there is lack of other rust, I would suspect frame damage from an accident.
Thank you for your response mate,
yeah, I initially suspected the same.
But after checking it more closely, the floor pan ribs are still straight and intact, not crushed or distorted like you’d expect from a side impact.
It actually looks more like the frame took a localized hit from underneath (maybe landing on a rock or something similar), rather than a lateral collision. Added a pic for you to see how it looks from the outside, you can see a impact, but doesn't look like a car accident.
There are no other signs of accident damage either — body lines are straight, doors align properly, and everything else checks out.
What surprises me though is that I wouldn’t expect a hit like that (from below) to actually crack a frame rail, which is why I’m trying to understand if this is a known weak point on FJ60s or if they tend to crack in this area from fatigue or use.
So I’m leaning more towards a localized impact/fatigue repair rather than accident damage.
Are the caved in rocker panel and hammered out door skin not signs of accident damage?
Thank you for your reply my friend,
that’s a fair question.
From what I can see, the rocker panel damage looks more like it was pushed in from below rather than from a lateral hit, more like contact with a rock or obstacle than a side collision.
The door skin also looks like it was hammered out rather than replaced, which could line up with that kind of lower, localized impact. If it were a true side impact with another vehicle, I’d expect the damage to be more extensive across the side of the truck, not just limited to one section. The width of another vehicle would typically affect a larger area, not just a single door and the rocker.
Also, I’d expect to see other structural signs like misaligned body lines, distorted floor pan ribs, or door fitment issues.
In my case, the body lines are straight, the doors align properly, and the floor pan ribs are still intact.
So while I can’t completely rule out some kind of past impact, the overall evidence seems more consistent with localized damage rather than a full lateral accident.
One thing I’m still trying to understand is whether this kind of repair affects structural integrity for off-road use, or if it’s generally considered acceptable as long as the repair was done properly.
This is why i don't think that it was caused by an accident, that panel intact, if she was crashed, that part gonna bend or weinkle after repair
What does the inboard side look like?
The inner side of the chassis, the one facing the transmission, has no reinforcement. At the level of the weld on the outer patch, there's a welded crack, so I think that confirms it was more due to fatigue or something similar. I didn't find any other cracks.
Very solid repair, if not rust than strange but solid.
Frame is designed for 5000 kilogram trailer so no worries.
Mine has a few patches in the frame, many frames are scrapped but no need for that at all, just cut it out and weld in (a bit more time but so much nicer for the bugs and cats)
Whatever happened happened, just have fun driving it.
Looks alright. I have seen a lot of bad repairs here in Canada. Go have some fun with it.
Thank you very much for your response, gived me confidente, time to enjoy the rig!!
