OK, so for desmog and vacuum lines. So far, I have blocked off the EGR ports on intake plenum and the exhaust manifolds, as you can see in the 3rd picture above. I did not install the air injection rail (plugged the ports) or the mess of vacuum hard lines, and did not install the smog pump. So, now for vacuum lines, here are my questions.
1) Do I need the VSV for the fuel pressure regulator? I have read both with some folks saying it is necessary and some saying it is not. Seems folks have successfully desmogged both ways. Here are two pictures I found of desmogged engines (sorry for the high tech computer screen photo snaps). The first has the VSV mounted on the intake plenum, with a vacuum line going from the VSV to the FPR on one side and to the dual port "gas filter" (thats what its called) on the intake from the other side. Second pictures does not appear to have the VSV used at all. Instead, the vacuum line from the FPR goes straight to the a vacuum port directly above on the intake plenum. Does anyone know for sure which way is correct, or maybe said better, which is going to make the engine run best? As I understand, without that VSV, there will be constant vacuum to the FPR, which means the FPR will maintain full pressure at all times. Is that correct? Will it make it harder to start cold or hot? I'd prefer to delete this VSV all together, but not at the expense of a well running engine.
2) second question is regarding that "gas filter" vacuum intake thing on the front of the air intake. I assume this is just a vacuum source and if I end up not using the FPR VSV, I can plug this hole. Does it serve any other purpose?
3) Question 3 is regarding the BVSV on the thermostat housing. It's this thing in the picture below. From what I understand, it controls the check valve for the charcoal canister? So I think one line would run to that valve, and the other is a vacuum source? I'm planning to still run the charcoal canister, so assume I need this. But some confirmation would be nice that I understand correctly.
I'll start with those questions, if anyone has some advice.
thanks.
Edit: I do have vacuum diagrams, but still get confused when it comes to deleting stuff. Slowly learning.
