Can I get a straight answer?
Tigard Oregon
I sold my street bike and have a few bucks to get a lift. I had it in my head if I wanted a 4" lift I would have to spend the $2500 at Sleeoffroad. A few weeks ago I go to the Copper State Cruisers monthly meet for the first time and talk to a couple of great guys, one being Kevin (Tools R Us). He said all you need is OME J's in the front, Heavies in the rear and recommended Cruiseroutfitters. Sounds great, I look them up and it's less than 1/2 the price of Slee, with 1/2 the parts count.
But then we have the notes at the bottom of the cruiseroutfitters that go like this:
• • OME CA77B Caster Kit will increase the caster by 2 degrees.*
• Trim Spacers may be required to trim vehicle to a maximum of 15mm (9/16") per coil. Spacers must be installed on the top end of coil.
• Fitting of N73L/N74L shocks requires minor bump stop & sway bar modifications front and rear, these are not available from OME and must be sourced/fabbed elsewhere.
• Fitting of 850J/863J coils may require minor panhard bar modifications front and rear, these are not available from OME and must be sourced/fabbed elsewhere.
So now im thinking besides the kit (coils, shocks, caster bushings) I will need some minor panhard bar modifications front and rear that must be sourced or fabbed elsewhere.....great, what the heck is this and where do I go for this and how much is this gonna cost me?
Then im on the Slee website, in the lift versus tire size FAQ I run across this little beauty:
"OME850J/OME863J coils and N73L/N74L shocks should be installed together, although they do not comprise a kit. Fitment of N73L/N74L shocks requires mandatory installation of .75" (20mm) Front and 1.25" (30mm) rear bump stop spacers to the front and rear suspension to prevent shock absorbers from bottoming out under full compression. These bump stop spacers are not available from OME and will need to be sourced from the installer."
So now I need bump stop spacers front and rear, well Kevin did mention this while we had our little chat, but just dont know where I would buy these or have them made for me. Or even if these are the exact measurements of spacers I need. Im sure Kevin would help me out with this one.
So do I need all the above, the kit for $800, trim spacers (from where?), some bump stop spacers (from where?) with sway bar and panhard modifications to be done (again, by who or is this something I can do in my garage?). Not to mention the fancy little tool to press the caster correction bushings in.
I have been in and out, up and down Ih8mud, there is so much debate, people say certain lifts it works for me, others say it sucked, Do I spend $1000?, or $2500 for the all inclusive Slee kit which seems to be bolt on with no mods to do. Can I even do it with a buddy in my garage(besides the bushings) or is it way over my head? I have yet to see a mention of how long to expect this modification to take, is it 1/2 a day or 2 weekends? Is there a reason for all the extra stuff in the Slee kit compared to the J kit?
Im no idiot, I can get stuff done on my vehicle with the proper instructions and have the resources to get the proper tools. My vehicle is a 1997 Lexus LX450 and all I want is a 4" or so lift with 35's. It wont ever be loaded down with gear and the only other mods planned are a a couple of new bumpers and maybe some sliders. I want to be able to do 80% of the trails here in Arizona, Colorado and Utah. I have money in my pocket and just dont know how to spend it. This headache makes me want to just spend the money on some bolt on's and a snorkel but I WANT THE LIFT!!!
Is this subject of lift still so up in the air?? If there was a poll, I would just do what the majority of other cruiser guys do, but there isnt such a thing.
Number one, Kevin is a great resource and his advice is valued by many.
Number two, there are a lot of things you can do. You can buy the Slee 4" kit. The Slee springs are a heavier rate than OME and will give a stiffer ride. Decide if thats what you want. You can run J's with a front spacer and L shocks. You can check out Frankies' offroad, there's OME comp springs also. You can worry about adjustable this and that later as you get a feel for it.
There's lots of combos and choice's to get a 4" lift.
Here's what I'm running:
J springs and L shocks
1-1/2 spacer up front
Landtanks castor plates, 7* IIRC
adj upper rear arms
adj panhards
stock driveshafts
3-1/2 swaybar drops (homemade)
2" rear bumpstop drops
I get some minor driveshaft vibes between 40-45 and again at about 72, other than that I have no driveshaft issue. I have front swaybar quick disconnects (homemade) and get pretty sweet flex.
I started out with the basic OME heavy lift/CC bushings and 33's and got the feel for it. From there I collected parts and put together my current and final lift.
AND, where is Avondale? I'm in Tucson and have installed a number of lift's on 80's and done a couple sets of CC bushings. I have all the neccessary tools and equipment and I'm usually agreeable to help.
I am sorry to inform you, but you are obviously infected with the cruiser disease. You are well into Stage 2 and only have to look forward to Stage 3 (head gasket????) and Stage 4 (just open your wallet). I personally sleep well at Stage 4 myself.
The best advice I got from a friend who infected me was to decide on what size tires you want to run First. This will dictate everything else. If you want 35 inch (315's) tires then 4 inches is where it is at, and Slee is pretty well spot on for what will need to be done to get your truck to do 80+ mph down the road without vibrations or excesive wandering. It will take one long day or 2 easy days to put the 4 inch lift on. :hillbilly:
Straight answer
I hope you get a staight answer...... Uhhh I dont have it but I'm interested. :D Suspect has something to do w/ bolt-on vs fab
elhombre you got any pics of your truck?? like your set up. hijack now over:cool:
Well you forget the black magic thats involved with lift selection! :) I swear the more you read the more you will get confused. Because of individual drivers sensitivities and how much "stuff" is in and on each rig answers vary. My choice,,,,,,,,heck I don't know I haven't figured out what to do either. My old FJ60 was easy. Springlift or SOA. akraven
I sold my street bike and have a few bucks to get a lift. [ ... ] Do I spend $1000?, or $2500 for the all inclusive Slee kit which seems to be bolt on with no mods to do. [... ] Is there a reason for all the extra stuff in the Slee kit compared to the J kit?
[ ... ] I have money in my pocket and just dont know how to spend it. [ ...]
I will attempt to address the above points and questions.
It seems to me that you are the perfect candidate for Christo's 4" kit. You have the money. You want a turn-key kit. You have little interest in fabbing stuff and you just want something that is going to work for you (not your words but reading between the lines.)
Go with the Slee 4" kit. It will take a full weekend if you've never done this before. You should try to get someone experienced to help you if you can though it is not required.
The Slee kit has the axle bump stops that you referenced. It works and you will save yourself a lot of trial-and-error if you decide to go that way. No welding. No plasma cutting. No hours and hours of drilling new holes and trying to figure out why things don't line up. No crappy drop brackets. High quality construction and materials.
The subject of "what lift" is up in the air because a lot of us will mix-and-match bits and pieces and some of us (me) can't be patient enough to save the money and buy everything at once. L-shocks one year, 4" springs the next year, tie rods and panhards the 3rd year.... and so on.
You know what you want and you have the money so do it once and start wheelin'
-B-
MadBaggins- I couldnt agree with you more about Kevin, he's a great guy, even offered to change the fluid in my fan clutch when I can get it down there. He knows his stuff, but researching all the possibilities makes me more and more confused. I want it right the first time, whether I spend a little or a lot. Avondale is 15 miles west of of the downtown Phoenix, not even 5 minutes from the new stadium where the Super Bowl was held. Hell yeah, I'd cruise down to Tucson for some lift install action if you want to help. I'll even throw in some man beverages and a dinner of your choice, or whatever. I got your # now!! So what am ordering now?
Azrael- you are following me around, I've been a member since March and you signed up in July. I use the same screen name as SVrider, just sold my bike for $3500 to a guy in Albuquerque and using some of the money to lift my rig. Getting a 2008 Triumph Speed Triple in January.
Beowulf- I would have to save a little more for the Slee 4" lift. You are totally right about fabbing stuff up, its definately not my deal, I dont have the know how or the tools and skills to do anything but simple things. Would there still be some headaches(on my end) if I went the J's and Heavies kit? I would make some phone calls right now and order up some parts if I knew what to 100% purchase, Thats why my wallet is full and my rig is at stock height in the garage. I'm also the type of guy that wouldnt mind getting a few things here and there to complete a great lift, I just dont know where to start. I hear people on the forum saying "I started with this, changed it to this" a bunch of times. I dont want to do that.
No. But you can get a lot of advice, some of which will actually be 'right' for you. The problem is, 'right' is different for many people. Get to another meet, bring a pen and pad, and ask Tools lots of questions. Know up front that it is nearly impossible to do it perfectly the first time, as things will crop up later that you won't think of now. Kevin can save you a lot of time in that area though, as he's been researching all this for a long time now.
-Spike
I never doubted Kevin at all, I just dont want to get in over my head with a garage full of parts ready to put on and then realize 1/2 way thru the install i needed another part I didnt buy or need something fabbed up. Leaving my rig on jack stands and stranded because i overlooked something. Not to mention I would hate to have the wife inquiring about the "not needed and waste of money" lift while I am dumbfounded with a problem. Snorkel is next on my list, not because I "need" it, but because it looks cool and she doesnt see the point in it. :)
I'll agree with Spike and Beowulf
Get over to another CSC meet and check out all the 80's there. Talk to Kevin and the other 80 owners.
If you don't really want to think about it much, then get the Slee kit. Personally I think his springs are to stiff for what I want, but it's all a matter of taste. There is no right answer.
Just be ware that the amount of lift you get with whatever spring will be in relation to how much added weight is on the truck. So my truck with bumpers, winch and sliders require Slee's 4" springs to get to a certain height a stock truck would be much higher with the same springs. If Kevin has advised the 850J-863 combo it's probably because you don't have that extra weight. That being said, the caster solution for any given height will be the same on your truck. So if you do run the 85J-863 springs and get the same amount of lift that the Slee 4" springs on a weighted truck yields then you will need the same caster solution.
I wouldn't put a lot of what's in that Slee document about running 35" tires. Most here running 35" tires are doing so and don't meet that documents criteria.
Buy F.O.R.'s kit if you can wait 8 weeks and everything is included in the kit. No problems with anything fitting that I've heard of. Oh yeah, in the mean time you can put 35's on your stock suspension and get around without scrubbing unless you go off-road. Even then going off-road isn't too bad depending on the obstacles you're going over.
There is no straight answer but it is pretty simple.
To lift the truck to 4" you need springs. Spring choice is based on what is on the vehicle in terms of weight of the truck. So you need to choose the springs correctly, otherwise you will get more or less height than you need.
You need shocks with the correct travel. OME L shocks happened to fit a 4" lift pretty well. There are other shocks, but nothing that bolts in without adapters. So you can get direct bolt in, that is valved for the truck, you can get bolt it with adapters and you have to figure out the valving.
You have to address the caster. There are different ways to do it, but most likely you are going to use caster plates. Caster plates are a compromise since they do not address the issue of the axle moving back, but they are cheap and relatively easy to do.
Once you fix caster you are probably going to have vibrations from the front driveshaft. You can buy a driveshaft or have one made with a double cardan joint. If you do not fix caster then you might not have vibrations but bad handling.
You need to make sure you do not overextend your brake lines. So either longer lines or drop the brackets.
You need to make sure you don't over compress whatever shock you install. We supply 2" block since we know that is what is needed for L shocks (and yes it is pretty conservative). Once you fit your tires you can cycle your suspension and determine exactly what you need and you can fab up your own. You may or may not need 2"
You might also have issues with the rear driveshaft. There are ways to deal with that. Either adjust the upper arms or lengthen the bottom arms. This is not always an issue at 4" but it could be.
Axles move side to side due to lift. So you need to address that if you want your driveability to be the best it could be. Front needs to be adjusted by lengthening the rod. Various ways to do it. Buy an adjustable rod, buy an adapter and weld it in, or cut and lengthen your rod. Do not drop the front panhard without setting the drag link at the same angle. That causes pretty bad bumpsteer.
You can do the same for the rear or get a drop bracket. There are lots of arguments about what is better. In general having the rod flat is the best, so a drop bracket at the frame side or a bracket to raise the axle end is a good idea, but more difficult to execute than a bolt in adjustable rod.
That is about the issues that need to be addressed. The reason there are no straight answers are that people are different. Some want their trucks perfect for a variety of reasons some throw tall springs on and live with the compromises. Only you can answer what you want.
Rick and others might not like what we wrote about 35" tires, but we also wrote that based on running a lot of different setups and conditions. Also we do not consider a 315 a true 35" tire. And there are small differences. Also important to note that it is written from a commercial companies perspective, and if we state we do not have rubbing, then we do not have it at all. Not "Oh, yes it touches the flares but that is ok and doesn't damage anything". So it is written from a conservative point of view.
The 2nd thing is that we put a kit together to try and give the "simple answer". You can also use what we suggest and source/fabricate or get DIY parts and achieve the same thing. Speaking to local people are invaluable since they know what the local conditions are and what works. I just caution you to make sure you compare apples to apples when you try to follow someone's setup.
Also, if possible ask to drive the vehicle and see how you like it. Drivability and what people accept for handing is very different from person to person. Hope this helped and that I did not skip over any part of the suspension. Once had one coffee so far.
Not exactly a true statement. They do not address panhards or any vibrations that might come up. Also in some cases the caster bushings they supply is not enough. And before anyone gets their panties in a knot about this statement, ask Nay (who is a customer of both of us and a big supporter of FOR) what he added to his kit.
I haven't heard any complaints post up if you've got them. I've heard people say the panhards were NOT needed even on the 4" and F.O.R. is 3.5". Maybe they were carrying more weight but anyway. Post up complaints of F.O.R. kits functionality not availability cause I know this is an issure right now.
This is not the case where some trucks are off-center and others are not. This is simple geometry. If you raise the truck 4" then it WILL, not might, move the body off-center with respect to the axles if you keep the stock panhard rod length.
Do you "need" to have the body centered over the axles?
Do you "need" to have the correct thrust angle when aligned on a machine?
If you don't care that your body is 1" to the right side then that is your decision. Like several have said, this is the type of decision that only the purchaser can make. I drove for 4+ years with the body crooked on the truck. Now, I am much happier with the body properly aligned with the longer panhards.
Same with caster but that has been discussed a thousand times. Some can live with it and some cannot, but the reality is that a truck with bad caster drives like crap and you can convince yourself that living with a crappy driving truck is "OK".
-B-
