Can anybody help me identify this carburetor component on my smog equipped 1982 FJ40
AC, air-conditioning I presume. My FJ does have a factory air. But , as you can see, the idle up is plugged. I’ve search the emissions/ carburetor schematics and can’t find any reference to where this gets connected to, if it gets connected.ac idle up?
I think folks don't understand what emissions equipment means....technically the only emissions items are EGR, Evap and Air Injection. The diaphragms on your particular carb are driver aids, Choke Breaker, Opener and A/C idle up.
Thank you for your response. Seems like this is part of the AC system. But , I’ve looked for the connection where it would take off the brake booster pump port by cylinder 5/6. And “no joy”. I can’t find a VSV with an empty port as well. If you or anyone has pictures of the VSV and port, I would really appreciate it.Ac idle up diaphragm, not an emissions item at all. Connects to a VSV which uses manifold vacuum off the brake booster port by Cyl 5/6 (but only needs manifold vacuum, that is just where Toyota put it).
Thanks, that would make a lot of sense. Perhaps the installed a/c with an old York compressor was dealer installed, rather than factory?If your truck wasn’t equipped with AC and someone swapped carbs then that is why you can’t locate the remaining infrastructure. The idle up diaphragm was only for ac and if it wasn’t a factory ac truck, no vsv or port on booster, simple as that.
Tell us the date code on carb (number/letter/one or two digit number) found on leading edge of carb top above sight glass and the date of manufacture of truck (vin plate). Then we can quickly tell you if it is original to truck.
I’ve never seen dealers install yorks for a/c, but I can assume it is possible.
BTW, the compressor is a YORK,( now TCCi) F210R model-1680, primarily used on F55.Thanks, that would make a lot of sense. Perhaps the installed a/c with an old York compressor was dealer installed, rather than factory?
