cams,cams & more cams
Did a rebuild on my 2F a while ago. Did all the usual suspects, bearings, rings, head done. All but the cam.(dumb as a stump i was)
Fires up good lots of power, but the lifters sound like a symphony of ballpene hammers.
Downey got high lift cams, torqer and horsepower also there are RV stile. Got to do something about the racket, so anybody got any input would be appreciated.
Pinhead is right, as usual. When i first got my '40 and started the motor it sounded like it was going to beat itself to death. A little tune-up and valve adjustment and it runs like a sewing machine.
This Tech article by Jim C covers it nicely.
http://www.birfield.com/~morgan/tech/valves.html
It is certainly worth a try before you spend $300+ and your time.:)
GL
Ed
Pin_Head said:
Are the valves properly adjusted? If so, that is about the best you can do. All the cams available use the same solid lifters, so they will all have the same solid lifter noise.
wish i could a good tape of an ol'2F sitting at idle, putting round town and reved up on the highway. that would make a great tape for use in the company supplied truck....
The valves are all in spec. The downey cams say u need to "crown " the lifters with their cams. I wonder if that would make a difference on thew stock setup? any thoughts.
