Caliper Bolt Fiasco
York, PA, USA
Doing the brakes on my '96 for the first time since I owned it. I have been driving it for over a year now.
Scary
Went to torque the bolts on reassembly and stripped one. It is apparent the bolts the PO used were not stock. Here is what the motley crew looked like,
Now all the bolts were 1.25 pitch on the threads.
The really scary part about using a "non-standard" bolt, is you really done't know what you are getting. I am 100% using what you have to get home or off the trail, but all bolts are not created equal. The major diameter on the 4 bolts ranged from 463 to 490 mils.
If someone has a bolt meant for that application, I would be interested to see what is supposed to be there. Here is a list that shows a comparison between SAE and Metric fasteners,
I chose to open the holes up and tap the knuckles for 9/16-18 grade 8 bolts versus getting new knuckles for $400 or used knuckles for $200.
Don't be afraid to give these bolts a heaping helping of extra torque. These are notorious for coming loose on their own, likely the reason for the mismatched bolts. Kinda scary when the caliper falls off at freeway speeds (speaking from experience).
IIRC, they torque to 90ft/lb, so tight. In my experience grabbing the torque wrench, doing it right, isn't that hard and gives better results. A heaping helping, s*** load, or good-n-tite is what leads to the above problem.
Hey. I didn't call for a shi+ ton. Let's not get carried away. Allow me to rephrase my recommendation. Heed the required torque and tighten to spec. Don't assume it's "tight enough," because it's probably not. And they like to back out. And that's no bueno.
Scary
The FSM has bolt torque tables so you can identify the suitable torque setting for each bolt type
Maybe @NLXTACY will make t-shirts with torque tables on it :idea:
You know what, I'd buy a little ready-reckoner book that had the exploded axle and hub diagram, bolt torque tables, fuse box diagram etc etc if it was printed on vinyl, or something that was oil and water proof, and could be kept in a trail repair tool bag
I use a hammer to torque these bolts. Haven't had one come out yet....
Four different bolts! That's nuts. I'd replace all four with OEM ones. Are those four suitable? Maybe- but I'd definitely sleep better at night knowing it had the proper bolts at the proper torque spec.
You CAN download the FSM on your Smartfone. I even carry the EWD on my crappy little I5.
Yeah, true. Good call. Hasn't even thought of that.
I find filthy grease and oil doesn't do my phone any favours.
I was thinking it would be good to have some thing you can grab and check with dirty hands. My FSM is slowly getting beat to a greasy pulp
Sorry to hijack.
Agree to the "tighten to factory spec." HOWEVER: just because its factory spec today doesnt mean it will be tomorrow.
Tighten them up to spec, put some miles on them and the check & tighten them again.
I tightened mine to spec with factory bolts and still lost one. If you lose one bolt your caliper will pivot on the remaining and cam the rotor. Its a very uncomfortable experience when you're driving down the road.
Like I said, my knuckle was toast. I opted to go with 9/16-18 grade eight, & locktite. Did both sides just in case. Not a hard job if you have the drills and taps. Good piece of mind. The knuckles are cast and the metal is pretty soft. I agree on the need to re-check torque from time to time.
Part of the reason I posted this was that a lot of folks are less informed about what is on their truck.
