Bypass Rear Heater
Has anyone bypassed the rear heater for their truck? I'm wondering if I should becasue those rear heater hoses get in the way. Living in NM there is no real need a rear heater. Plus I'm thinking the the front is sufficient. Suggestion, comments welcome and appreciated.
just disconnect the rear heater at the fire wall and loop a piece of heater hose from one side to the other and then just remove the rear unit all together.
You might be able to find the "caps" from www.sor.com to cap the ends.
PM me if you want to sell the rear heater.
You actually do not want to do this...
if you "short circuit" the rear heater connections ALL your coolant will flow through this low-resistance circuit instead of your front heater...
plug them seperatly with 5/8" bolts...
Just install a shutoff in the line to the rear heater on the feed side. If you need the heater, you can turn it back on.
I did something similar for the entire heating system in the engine compartment. Don't need either heater in the summer. There are two types of shutoffs. Manual and remote. Both splice into the hose. The manual type is like a little faucet. You just turn a knob. The remove uses a lever arm and a choke type cable to the dash. I installed the latter. Your setup would likely only need the manual type down somewhere along the floor.
I've been in some mighty chilly morning wakeups in New Mexico, but if you're a flatlander at least think about whether you ever have to defrost your windshield. The front heater is an either up or down thing. If you're using it to warm the cab you won't be able to direct heat to the windshield. When you have both the rear can heat the cab while the front does the windshield.
Besides, it's part of the charm of the trucks. Makes people ask about that thing in the back.
amandap said:
One other reason I've considered keeping mine in back of my 66 is to be able to dump heat out the back in case of overheating situations. Better than dumping it in the front on a hot day. It does take up a bit of space tho. Shut off valves are a must, in my opinion.
:idea: that has saved me on numerous stoplights in the past
run a small loop under the dash, the hose will pinch but so what! this way you still have heat and defrost up front, I need to rebuild all of my coolant tubes to the rear heater and temporarily disconnected mine.
:confused::confused::confused::confused:
CruisinGA is correct.
Think of how the heater lines split into "Y"s just inside the firewall.
Y Y
If you just loop two of the rear heater branches with an open hose the coolant will follow the path of least resistance and a large percentage will bypass the front heater. Due to the design not ALL will bypass, but enough to make a difference in total heat output.
Better to block the rear branches completely.
A simple solution might be to just put a tight fitting ball bearing or marble into the hose loop.
Any good NAPA store should carry heater pipe caps, they come in a variety of dimensions and are of heater hose material. They're pretty inexpensive and come two/package. Use hose clamps. When I bought my truck the connections had been "looped", and the heater worked poorly. Works much better now, and there isn't a looped hose hanging down.
If you want to totally ditch the rear heater, then just take the metal "Y" pieces out. Run a heater hose from the top of the head to the front heater core, and then run another from the other nipple of the heater core to the lower radiator hose nipple. No worries about short circuiting, or crude bolts in hoses or caps cracking and coming off in the cab. All the fluid will pass through it this way. As for an easy shutoff put a ball vavle in the cab in the line between the head and heater core. Then you have heat on demand.
Personally, I live in NW Colorado, my 40 is always cold in the winter, rear heater or not, I run them both full blast, and it doesn't ever really warm up that much in there. I keep my rear heat because of the uniquness and it does help, but it is a pain in the butt, takes up alot of space and is easily damaged.
Damn, I never realized that. Guess I'll plug up the hoses.
http://www.eurekaboy.com/f250/heaterhose.htm
Like I mentioned in my earlier post, if you are retaining the rear heater, then install a heater hose shutoff valve.
Cheap and effective. Install it on the feed side, not the return side. Click the link.
