In the early days of piston engines there were two kinds of oil filtration,
full flow,
where all oil coming out of the oil pump passes through a filter and then on to the diffrnt lubricated parts of the engine, this is how modern engine are set up.
bypass filtration,
where most of the oil went straight to the parts and a small portion of the pumped oil was passes through a filter and then routed back to the pan, eventually any particle in the oil would get caught in the filter, bypass filters were generally finer as they did not have to deal with the full flow of engien oil,
Today bypass filtration is added to an engine that also has a full flow filter,
you tap off a small amount of oil and pass it through a super fine filter, much finer than the full flow filter, then after filtering the oil is routed back to the pan eventually all of the oil will pass through this filter (usually every 5-15 min or so)
The one K is running uses a roll of toilet paper as the element, you replace the TP on a schedule and it takes with it a portion of the sump oil that is replenished, many stop chaning their oil, only changing bypass filters and full flow filters and topping off, the topping off replenishes the additives, other bypass filters remain in place and the oil and full flow filter are changed as normal, the bypass can remain until plugged or be changed with the oil and FFfilter,
benefit is very clean oil, how much this reduces wear how much is added to the life of the engine as opposed to the cost of the setup and elements is up for debate but it certainly a good thing, if you go to the no oil "change" then another is reduced maintenance costs and time.
read more
http://theoildrop.server101.com/forums/postlist.php?Cat=0&Board=UBB36
BTW If you look into a bypass oil filter stay away from the Amsoil dual bypass, it is the easiest to install as you do not have to plumb a return but it purposely restricts the main oil flow to the engine.
